Which hood scoop? #885181
12/21/10 05:50 PM
12/21/10 05:50 PM
California
X
XLR8S U Offline OP
XLR8S U  Offline OP
X
California
Six pack, Hemi, or Chevy cowl?
Re: Which hood scoop? [Re: XLR8S U] #885182
12/21/10 08:04 PM
12/21/10 08:04 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
cowl
Re: Which hood scoop? [Re: joshking440] #885183
12/21/10 08:15 PM
12/21/10 08:15 PM
California
X
XLR8S U Offline OP
XLR8S U  Offline OP
X
California
Looks good on your car, just not sure cause my hoods longer.
Re: Which hood scoop? [Re: XLR8S U] #885184
12/21/10 11:20 PM
12/21/10 11:20 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
My bird catcher
Re: Which hood scoop? [Re: XLR8S U] #885185
12/21/10 11:21 PM
12/21/10 11:21 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Tall sixpack
Re: Which hood scoop? [Re: B1KILLER] #885186
12/21/10 11:22 PM
12/21/10 11:22 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Re: Which hood scoop? [Re: B1KILLER] #885187
12/21/10 11:52 PM
12/21/10 11:52 PM
California
X
XLR8S U Offline OP
XLR8S U  Offline OP
X
California
I will definitely consider that, B1.
Kinda want to stay with the mopar scheme, but the hole in hood is 3in tall and pretty long, and in a weird spot.
Re: Which hood scoop? [Re: XLR8S U] #885188
12/22/10 09:15 AM
12/22/10 09:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
What car??? I went w/ a 4" cowl, but if it was an A-body I would have used a Hemi scopp, if it was a 66-67 B I would have used a WO scoop. Depends on the car.
Coming soon!!!!
Re: Which hood scoop? [Re: Mr.Yuck] #885189
12/22/10 09:17 AM
12/22/10 09:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
another pic..pre-black. It will be body color w/ black out and 440 call outs by spring.
Re: Which hood scoop? [Re: XLR8S U] #885190
12/22/10 01:39 PM
12/22/10 01:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I really dislike cowl hoods on Mopars. The tall hemi scoops look like someone's trying to compensate for something.
It's hard to do something on a Charger that looks good. They never came with scoops so they all look out of place.
- Stu Harmon
Re: Which hood scoop? [Re: XLR8S U] #885191
12/22/10 02:04 PM
12/22/10 02:04 PM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
I went with the sixpack scoop on my 70 Chargervert. I installed it from the underside to prevent cracking issues. I don't care for Chevy scoopps on Mopars.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: Which hood scoop? [Re: feets] #885192
12/22/10 02:47 PM
12/22/10 02:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Yup but sometimes you need the room.
Re: Which hood scoop? [Re: XLR8S U] #885193
12/22/10 03:58 PM
12/22/10 03:58 PM
IMGTX Offline
IMGTX  Offline
While it may be a little late, the size and location of that cutout pretty much means you will have an offset scoop or a scoop that is about 4' wide.
Any scoop 4'wide will be odd looking. If you do a bird catcher you will be catching a lot of drag.
If looks are important and you could reroute the intake tube to be more centered, you could have a better looking scoop. Maybe build a flat wider tube instead of a round wide tube.
Myself, I would reroute the tube and graft a 70 superbee style on it.
I am not into cowl hoods on mopars but it looks like that is you best choice for aerodynamics if you can't move that tube.
Re: Which hood scoop? [Re: IMGTX] #885194
12/22/10 04:09 PM
12/22/10 04:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I thought about this as well...
Re: Which hood scoop? [Re: Mr.Yuck] #885195
12/22/10 08:06 PM
12/22/10 08:06 PM
California
X
XLR8S U Offline OP
XLR8S U  Offline OP
X
California
i like the cowl on your 70. Really like the bee scoop on the other 70,but its too narrow 4 me. dont really want to move any piping around. guess i will make something work. thanks for all the input everyone.
Re: Which hood scoop? [Re: XLR8S U] #885196
12/22/10 10:03 PM
12/22/10 10:03 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
I'm not against cowl hoods on Mopars (except early B-bodies). However, 68-70 Chargers are a real tough one to do just about any scoop because of all the contours of the hood. Couple years ago I saw black 70 Charger with a 70 Road Runner skin (air grabber) grafted onto the Charger hood. Looked GREAT! Maybe you could do something like that... Just a little taller and wider. Or maybe you could do something with the Charger hood skin. Like raise it up and turn it into it's own buldge hood. I saw this effect done to a 68 Superbee hood and it looked pretty slick.
Re: Which hood scoop? [Re: pinkduster] #885197
12/22/10 10:59 PM
12/22/10 10:59 PM
Coronado, CA
go-fish Offline
go-fish  Offline
Coronado, CA
I say leave it! I drove around for a year with no hood showing off my Procharger.
I like the look of the stock hood with that hat sticking through. Like someone said, any scoop looks out of place because they never came with one.
If there must be a scoop I would say a wider cowl that goes across most of the hood. Not just a generic Chevy scoop but maybe two grafted together to make a wide one.
70 'cuda: ProCharged 408, Tremec 5 speed, S60,triangulated 4 link, Hydroboost and Wilwoods
Re: Which hood scoop? [Re: pinkduster] #885198
12/23/10 12:04 AM
12/23/10 12:04 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
this one? It is TUFF. $$$ for all the stuff and to blend it.
Re: Which hood scoop? [Re: Mr.Yuck] #885199
12/23/10 12:31 AM
12/23/10 12:31 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
Go with Mr. Yuck's hoods
Re: Which hood scoop? [Re: Mr.Yuck] #885200
12/23/10 06:30 PM
12/23/10 06:30 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A good friend of mine built this car. He did a great job of blending the two hoods, especially when you consider that he's not a bodyman. That car has a Eddy headed 500" six pack backed by a 4 speed. He didn't cut corners when building it and it turned out nice.
He sold off his Chargers (one wing car to go) and got into Harleys because those guys don't sit around in parking lots collecting dust.
- Stu Harmon
