Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}}
[Re: blown572dart]
#884957
12/21/10 10:31 AM
12/21/10 10:31 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
I dont have a good shot of the other side since it's all off the car now, but the feed went through the t-ram, down along the valve cover and followed the factory route next to the alternator. This was all 3/8 stainless and high pressure compression fittings I got from a job I was on,
[Re: DJVCuda]
#884958
12/21/10 10:45 AM
12/21/10 10:45 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Nice clean look Dave (as usual) I like the hard line look....of course the Edelbrocks feed from the passenger side but would only make the routing easier....!!!!! Probably use a tee fitting with an 1/8 fitting for a fuel pressure gauge
Getting closer....wheels and pulleys being dropped off today to get powdercoated and the Valiant will be hitting the body shop next month....finally
Rickster
[Re: DJVCuda]
#884959
12/21/10 12:43 PM
12/21/10 12:43 PM
Posts: 1,845 Tampa
DusterDave
Tampa
[QUOTE] This was all 3/8 stainless and high pressure compression fittings I got from a job I was on,
In other words, you got them at a five finger discount.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DJVCuda]
#884962
12/21/10 07:59 PM
12/21/10 07:59 PM
Posts: 1,049 ohio
all spooled up
ohio
[QUOTE]
why dont you worry about that black smoke huffin, wiring mess of a car you sent up here and not my buisness!
[Re: rickstershemi]
#884964
12/21/10 08:26 PM
12/21/10 08:26 PM
Quicktree
Looking to see how you guys have set up your small block tunnel ram fuel lines with a mechanical pump....?????
I'm going to run (2) 500 Edelbrock Thunder Series AVS single feed carbs in-line on a Weiand Tunnel Ram from a Carter performance series mechanical pump with alternator in the stock location.
Street 408 stroker....I was planning on not running a regulator....?????
Rickster
are you sure a mechanical pump will be enough for 2 carbs at high rpm? or is this your grocery getter?
[Re: blown572dart]
#884965
12/21/10 08:27 PM
12/21/10 08:27 PM
Quicktree
Sorry can't help ya but Tony might have som insight.
I know nuttin one carb is hard enough
[Re: DusterDave]
#884966
12/21/10 08:42 PM
12/21/10 08:42 PM
DJVCuda
Atco NJ
[QUOTE]
Wow, you're even more thin skinned than I imagined!
ya think?
yeah.... you know me all so well...
[Re: Quicktree]
#884967
12/21/10 08:47 PM
12/21/10 08:47 PM
DJVCuda
Atco NJ
Rickster
my carter mechanical pump ran mine fine - at 400 horses at the crank - to 6500
[Re: DJVCuda]
#884968
12/21/10 08:49 PM
12/21/10 08:49 PM
Quicktree
Rickster
stroker motor?
[Re: DJVCuda]
#884971
12/21/10 08:54 PM
12/21/10 08:54 PM
Quicktree
no - but he can make an educated judgment based on my rpm and horsepower range what his fuel needs are from my experiences.
do you think the fuel demands for a stroker would be different from your combo?
[Re: Quicktree]
#884972
12/21/10 09:00 PM
12/21/10 09:00 PM
rickstershemi
Rickster
Yes it will be mostly street driven and yes the Carter pump will feed the 408 with no problem.....it's doubtfull this motor will ever see 6000rpm, but it's sure to have plenty of torque
Now go play with your squirrel
Rickster
[Re: DusterDave]
#884974
12/21/10 09:20 PM
12/21/10 09:20 PM
rickstershemi
Rickster
Rickster
I thought he had a shaved hamster.
That Too
Rickster
[Re: DusterDave]
#884975
12/21/10 09:48 PM
12/21/10 09:48 PM
Quicktree
Rickster
Rickster
thats ok I heard you have a gerbil on a string
