Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DusterDave] #884975
12/21/10 09:48 PM
12/21/10 09:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Looking to see how you guys have set up your small block tunnel ram fuel lines with a mechanical pump....?????
I'm going to run (2) 500 Edelbrock Thunder Series AVS single feed carbs in-line on a Weiand Tunnel Ram from a Carter performance series mechanical pump with alternator in the stock location.
Street 408 stroker....I was planning on not running a regulator....?????
Rickster
are you sure a mechanical pump will be enough for 2 carbs at high rpm? or is this your grocery getter?
Yes it will be mostly street driven and yes the Carter pump will feed the 408 with no problem.....it's doubtfull this motor will ever see 6000rpm, but it's sure to have plenty of torque
Now go play with your squirrel
Rickster
I thought he had a shaved hamster.
thats ok I heard you have a gerbil on a string
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: Quicktree] #884976
12/22/10 12:04 AM
12/22/10 12:04 AM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
We all know them stories about gerbal
and rearends not mixxing
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: Quicktree] #884977
12/22/10 08:11 AM
12/22/10 08:11 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Rickster
Rickster
No, that's your butt buddy Richard Gere.
Gone to the dark side with an LS3 powered '57 Chevy 210
