{{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} #884955
12/21/10 10:13 AM
12/21/10 10:13 AM
Lehigh Acres, Florida
rickstershemi Offline OP
Looking to see how you guys have set up your small block tunnel ram fuel lines with a mechanical pump....?????
I'm going to run (2) 500 Edelbrock Thunder Series AVS single feed carbs in-line on a Weiand Tunnel Ram from a Carter performance series mechanical pump with alternator in the stock location.
Street 408 stroker....I was planning on not running a regulator....?????
Rickster
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: rickstershemi] #884956
12/21/10 10:26 AM
12/21/10 10:26 AM
Orlando Florida
blown572dart Offline
Orlando Florida
Sorry can't help ya but Tony might have som insight.
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: blown572dart] #884957
12/21/10 10:31 AM
12/21/10 10:31 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I dont have a good shot of the other side since it's all off the car now, but the feed went through the t-ram, down along the valve cover and followed the factory route next to the alternator.
This was all 3/8 stainless and high pressure compression fittings I got from a job I was on,
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DJVCuda] #884958
12/21/10 10:45 AM
12/21/10 10:45 AM
Nice clean look Dave (as usual) I like the hard line look....of course the Edelbrocks feed from the passenger side but would only make the routing easier....!!!!! Probably use a tee fitting with an 1/8 fitting for a fuel pressure gauge
Getting closer....wheels and pulleys being dropped off today to get powdercoated and the Valiant will be hitting the body shop next month....finally
Rickster
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DJVCuda] #884959
12/21/10 12:43 PM
12/21/10 12:43 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
[QUOTE]
In other words, you got them at a five finger discount.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DusterDave] #884960
12/21/10 06:56 PM
12/21/10 06:56 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
dave post pictures of your ice skating rink in your back yard....lol...
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DusterDave] #884961
12/21/10 07:56 PM
12/21/10 07:56 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
[QUOTE]
why dont you worry about that black smoke huffin, wiring mess of a car you sent up here and not my buisness!
Jim - I'll post it in the general section...lol
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DJVCuda] #884962
12/21/10 07:59 PM
12/21/10 07:59 PM
ohio
all spooled up Offline
ohio
[QUOTE]
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DJVCuda] #884963
12/21/10 07:59 PM
12/21/10 07:59 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
[QUOTE]
Wow, you're even more thin skinned than I imagined!
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: rickstershemi] #884964
12/21/10 08:26 PM
12/21/10 08:26 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Rickster
are you sure a mechanical pump will be enough for 2 carbs at high rpm? or is this your grocery getter?
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: blown572dart] #884965
12/21/10 08:27 PM
12/21/10 08:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I know nuttin one carb is hard enough
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DusterDave] #884966
12/21/10 08:42 PM
12/21/10 08:42 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
[QUOTE]
ya think?
yeah.... you know me all so well...
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: Quicktree] #884967
12/21/10 08:47 PM
12/21/10 08:47 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Rickster
my carter mechanical pump ran mine fine - at 400 horses at the crank - to 6500
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DJVCuda] #884968
12/21/10 08:49 PM
12/21/10 08:49 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Rickster
stroker motor?
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: Quicktree] #884969
12/21/10 08:51 PM
12/21/10 08:51 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
no - but he can make an educated judgment based on my rpm and horsepower range what his fuel needs are from my experiences.
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DJVCuda] #884970
12/21/10 08:52 PM
12/21/10 08:52 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
and if i ever got 400 at the crank from a stroker motor and t-ram i'd never post in another thread..lmao
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DJVCuda] #884971
12/21/10 08:54 PM
12/21/10 08:54 PM
Q
Quicktree Offline
Quicktree  Offline
Q
do you think the fuel demands for a stroker would be different from your combo?
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: Quicktree] #884972
12/21/10 09:00 PM
12/21/10 09:00 PM
Rickster
Yes it will be mostly street driven and yes the Carter pump will feed the 408 with no problem.....it's doubtfull this motor will ever see 6000rpm, but it's sure to have plenty of torque
Now go play with your squirrel
Rickster
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: rickstershemi] #884973
12/21/10 09:05 PM
12/21/10 09:05 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Rickster
Rickster
I thought he had a shaved hamster.
Re: {{{ SHOW ME YOUR SB TUNNEL RAM FUEL LINES }}} [Re: DusterDave] #884974
12/21/10 09:20 PM
12/21/10 09:20 PM
Rickster
Rickster
That Too
Rickster
