Exhaust flex joint failure #884103
12/19/10 09:55 PM
12/19/10 09:55 PM
Andrews,In. U.S.of A.
67_Satellite Offline OP
Anyone ever have this happen to them?This is in the crossover pipe. The inner braid of the flex joint is "blown" down to the outlet end. It's still attached at the inlet end, just bunched up at the exit. The opening is only 1" in diameter to pass all the exhaust from the driver side bank to the passenger side. W.T.F.
Re: Exhaust flex joint failure [Re: 67_Satellite] #884104
12/19/10 10:00 PM
12/19/10 10:00 PM
The rest of the pipe
Re: Exhaust flex joint failure [Re: 67_Satellite] #884105
12/20/10 01:54 AM
12/20/10 01:54 AM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
Very common issue with the braided stainless on the inside as well. Just cut it out and make sure to check the turbine wheel. Usually some of the wires end up in there and hurt the ehaust wheel. The ones I bought were ROL I think and they had no braiding on the inside.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: Exhaust flex joint failure [Re: CW25] #884106
12/20/10 02:08 PM
12/20/10 02:08 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I saw a thread about a similar failure on the Turboforums. x2 on what CW25 said...
A slip joint might be more robust and turbo-friendly.
Re: Exhaust flex joint failure [Re: Fury Fan] #884107
12/20/10 07:50 PM
12/20/10 07:50 PM
Thanks guys.
Re: Exhaust flex joint failure [Re: 67_Satellite] #884108
12/24/10 09:17 AM
12/24/10 09:17 AM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
yup happened to me on my 1st setup...you can buy them without the braid in them for forced induction applications...
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
