340 combos??? #884048
12/19/10 09:18 PM
12/19/10 09:18 PM
NJ
440challenger Offline OP
NJ
Ok i have a 340 block and a set of stock J heads. I want to build a stout motor which will go in a challenger behind a 4 speed with a 3.23 gear. Whats a good HP build using iron J heads?
I looked in the archives i didnt see any proven SB combos. Thanks!
Re: 340 combos??? [Re: 440challenger] #884049
12/19/10 10:02 PM
12/19/10 10:02 PM
Hartville OH
mini340hemi Offline
mini340hemi  Offline
Hartville OH
Turn that 340 into a 416, I wish I did. I'm thinking 10 to 1, mid 500" lift solid cam, air gap,750 DP, nice set of 1 3/4" headers would run pretty good.
Re: 340 combos??? [Re: mini340hemi] #884050
12/19/10 10:32 PM
12/19/10 10:32 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
I'll give you mine but I have W2 heads. 30 over, 10 to 1, Racer Brown SSH25 cam, Mope dual intake w/ thermoquad. I have a 727 so I have to run a 3k conv. Also 4.10 gears. Pulled 400 on the dyno. The cam is small for what the heads can do so I may just bump up the rockers to 1.6s. No track time but it pulls the ole B body pretty good.
Re: 340 combos??? [Re: mini340hemi] #884051
12/19/10 10:32 PM
12/19/10 10:32 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Oh yea Baby!!!
Re: 340 combos??? [Re: Mr340] #884052
12/19/10 10:56 PM
12/19/10 10:56 PM
Outside
thedriver Offline
thedriver  Offline
Outside
340, ported j's, BIG cam... consider a roller, 750 carb, that'll make it pretty good....for a 340. if you want real power tho, better make a 416.
i run a 340, 10.5:1 cr, 750 mighty demon, ported air gap, eddie heads, 285HEHL cam, and its good for low 12's. is it fast enough? no, not at all. respectable yes. but i always say, that if i knew what i know now, i woulda started with a BB, or stroked the 340.
1973 challenger
Dana. 4 speed. Low deck.
Re: 340 combos??? [Re: thedriver] #884053
12/19/10 11:36 PM
12/19/10 11:36 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
4" crank, .020 over (4.060 ring pack is fairly inexpensive), 9.5:1 CR, 340 rods, dual-plane, TQ or 750 Holley or AVS, Engle 214/224 @ .050, .470/.504 lift @ 4* advanced, MP ignition, 1 3/4 headers. Balance it.
With that gear & weight, it'll pull strongly, idle nicely but with authority, and pull high-teens highway MPG. Did that build on a 406" 360 and I'd do it again.
Avoid the MP stroker kit cast pistons, they're actually for Chevy rods.
Re: 340 combos??? [Re: topside] #884054
12/20/10 12:38 AM
12/20/10 12:38 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Why the tiny cam?
Re: 340 combos??? [Re: ademon] #884055
12/20/10 02:35 PM
12/20/10 02:35 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
Here' my 360 combo, and ymmv but here goes (340 whp / 350 wtq). 10.2:1 compression, out of the box edelbrock heads, holley 750 vs carb, air gap intake out of the box, hooker super comp 1 5/8" headers, crane hyd. retrofit roller cam 112 lsa, 108 installed, 230/238 @ .050, .528/.548 lift, crane gold roller rockers.
I used to run Iron J-heads ported out before these with slightly lower compression (10.07:1) on the same short block with 1 step down cam (222/230 @ .050, .509/.528 lift) and she put 305-310 at the wheels with that combo.
Good luck!
Re: 340 combos??? [Re: 440challenger] #884056
12/20/10 03:49 PM
12/20/10 03:49 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Any chance of going with more gear? 3.55? 3.91?
If not, I'd say "go stroker" too. The big arm will help overcome that mild gearing. Small blocks need freedom to spin/rev. Big blocks are more forgiving, so make big cubes with the stroker.
Otherwise the 3.23's will limit cam, carb and port/runner volume.
Re: 340 combos??? [Re: Dean_Kuzluzski] #884057
12/20/10 08:37 PM
12/20/10 08:37 PM
NJ
NJ
Well with the 4speed i thought i would be able to pull the 3.23s. I have a 340 block 60 over already.Im thinking of going with the stroker. I heard theres no clearincing needed with the 4in crank and I beam rods. .60 over with stroker crank = 422. What do you guys think? will stock X or J heads work? I know an aftermarket or ported head will be better but i dont mind not being able to get the full potential out of the combo becuase it would end up saving me at least 1500$
Re: 340 combos??? [Re: 440challenger] #884058
12/20/10 09:17 PM
12/20/10 09:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Ademon, the "tiny" cam was because of the stock converter, 3.21 gear, factory AC, and I already have a few other hotrods and a race car. It sounded much bigger than the specs, had perfect driveability, pulled good vacuum, and returned good MPG. I wasn't after something peaky and if you're familiar with Engle, they're very fast ramps. Personally, for a street car, I'm not into ill-mannered cam timing or "drive-in" posers.
I would also go with the minimum overbore needed to clean the cylinders up and use a "shelf" ring pack; thicker cylinder walls make more power, and are better for longevity & future freshenings, than the last .020 or .030 one can remove from the bores.
Re: 340 combos??? [Re: 440challenger] #884059
12/20/10 09:38 PM
12/20/10 09:38 PM
Central Vermont
DUSTERB'D Offline
DUSTERB'D  Offline
Central Vermont
STARTED WITH THE SAME THING AS YOU ENDED UP WITH A STROKED 416, PORTED J HEADS, MADE 495 HP AND 525 TRQ, RUNS 10.8 IN MY DUSTER!
Re: 340 combos??? [Re: DUSTERB'D] #884060
12/22/10 02:53 AM
12/22/10 02:53 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
I'm surprised the "340tool" hasn't chimed in yet
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: 340 combos??? [Re: 69L78Nova] #884061
12/22/10 01:04 PM
12/22/10 01:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't think he's here anymore .
Re: 340 combos??? [Re: justinp61] #884062
12/22/10 08:41 PM
12/22/10 08:41 PM
fiddlerfingers Offline
I just got my motor built by Mike Liston at MRL Performance. 71 340 block redecked and bored .30 over, 416 stroker kit 10:5 comp., Voodoo Cam 60405, Edelbrock RPM performer Heads (Re ported),Hughs roller rockers 1/6 ratio, M-1 single plane ported intake,Bigs stage 5 750 carb, made 502 HP at 5650 RPM and 507 torque ft-lb at 4308 RPM on the dyno. Chassis Dyno results will come in the spring....
Re: 340 combos??? [Re: fiddlerfingers] #884063
12/23/10 03:20 AM
12/23/10 03:20 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I just got my motor built by Mike Liston at MRL Performance. 71 340 block redecked and bored .30 over, 416 stroker kit 10:5 comp., Voodoo Cam 60405, Edelbrock RPM performer Heads (Re ported),Hughs roller rockers, single plane ported intake,Bigs stage 5 750 carb, made 502 HP at 5650 RPM and 507 torque ft-lb at 4308 RPM on the dyno. Chassis Dyno results will come in the spring....
I'm building about the same 416 build with a smaller cam; the Comp XE274S solid. Full Ported E-brock heads, M1 Single Plane, Silver Claw 750, Comp rollers.
Hope to make 425HP ??
Re: 340 combos??? [Re: autoxcuda] #884064
12/23/10 06:19 AM
12/23/10 06:19 AM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
Go with the stroker kit, cheapest horsepower you can get
Thad
Re: 340 combos??? [Re: olemopar] #884065
12/23/10 01:31 PM
12/23/10 01:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Thad
My 408 thinks it's a big block .
Re: 340 combos??? [Re: 440challenger] #884066
12/23/10 03:49 PM
12/23/10 03:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Sell the 340 block to somebody that haaaaaaaaaaaaas to have it. If you want to stay SB get a roller (magnum)360 and have at it. Storked is nice but a .030 360 should have plenty of grunt.
Coming soon!!!!
Re: 340 combos??? [Re: 440challenger] #884067
12/23/10 03:53 PM
12/23/10 03:53 PM
Maryville tn
67coronetman Offline
Maryville tn
I had a 73 Dart factory 340 car with the entire eddy heads intake carb and cam set up and that car ran very good and was very quick.!
Old car are me......
