Rotisserie Restoration #883460
12/18/10 11:29 PM
12/18/10 11:29 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
How much would it be to partially Rotisserie Restore my 1968 Dodge Dart. I would like the bottom to have the factory undercoat and I would like the entire body to just look flush and nice so I won't have rust coming back. There is barely any surface rust on the car and the trunk. It is really solid. Suppose to be a vinyl top car. I don't need it to be painted though, I can have my mechanics do that. I would like to put a 6.1L HEMI in it and possibly a T56 Viper Transmission. So I was wondering if I would have to increase the size of the trans tunnel because I would have to use a Quicktime bellhousing adapter. Reilly Motorsports did something similar with attaching it to a 528 HEMI in a 69 Dart. Any advice would be great. This will be a long 4-6 year project I hope to do mostly myself. Thank you.
Anybody know a good Rotisserie Shop near Los Angeles, CA?
Picture of the Trans Tunnel in the 528 Dart:
Re: Rotisserie Restoration [Re: MuuMuu101] #883461
12/19/10 06:50 PM
12/19/10 06:50 PM
Puttin' on the foil in Charles...
not_a_charger Offline
Mr. Big Shot Moparts Moderator
You're going to spend the money to have the bodywork done on a rotisserie, but have a mechanic paint the car? Not that there aren't mechanics out there that also know how to paint, but why not get the body/paint done by the same folks?
Also, your "What color should I paint my car" topic is in the General forum.
Earning every penny of that moderator paycheck.
DBAP
Re: Rotisserie Restoration [Re: not_a_charger] #883462
12/19/10 08:01 PM
12/19/10 08:01 PM
SoCal
SoCal
Thanks for moving it. Well, the paint would be cheaper at my mechanics because they give me a discount but they don't have a rotisserie setup and probably don't know how to enlarge the trans tunnel.
Re: Rotisserie Restoration [Re: MuuMuu101] #883463
12/19/10 08:05 PM
12/19/10 08:05 PM
My point is that if you're going to go through the trouble and expense of having a body shop do a rotisserie job on the body and get the body nice and smooth, you'll likely come out ahead if you spend the money to have them paint it. Saving money on paint after spending big money on body isn't a wise decision. Enlarging the trans tunnel isn't a huge deal. If the mechanic can't do something relatively simple like that, I doubt he's got the skill to lay down a quality paint job.
A mediocre paint job will make the nice bodywork look like garbage.
DBAP
Re: Rotisserie Restoration [Re: not_a_charger] #883464
12/19/10 08:10 PM
12/19/10 08:10 PM
SoCal
SoCal
My dad uses them for the company cars at his work so they give us a discount but you are right. They are an autobody shop but they tend to do a sloppy job. Like I had them do some work on my Stealth and I redid the paint job and added that little sparkle in it and they left some primer in between the trim and the body and there were some bubbles. So how much would it cost to have it Rotisseried and Painted?
Re: Rotisserie Restoration [Re: MuuMuu101] #883465
12/19/10 08:33 PM
12/19/10 08:33 PM
There's no way anyone can give you an accurate cost for that work via the internet without the following:
1) a detailed description of exactly what body work needs to be done
2) pictures to accompany the description
3) Info on what parts need to be replaced and the cost of those parts
4) The prevailing labor, paint & material, and tax rates in your area
5) Are you going to paint it base/clear or single stage?
Doing the body and paint on a rotisserie, and doing a QUALITY job, will run you into the 5 figures easily.
DBAP
Re: Rotisserie Restoration [Re: not_a_charger] #883466
12/19/10 08:44 PM
12/19/10 08:44 PM
SoCal
SoCal
Well, it's a pretty solid car. Quarters are nice and the trunk has been replaced by the previous owners. There is little surface rust on the car that would have to be removed, and some surface rust in the trunk. It has a really straight body as it is. And I would like to paint it blue as shown above. While also enlarging the trans tunnel and adding a manual shifter whole. The car is currently a auto on the column and I plan on putting a Viper Transmission in it with a Quicktime Bellhousing.
Re: Rotisserie Restoration [Re: MuuMuu101] #883467
12/19/10 09:31 PM
12/19/10 09:31 PM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Between 7000 and 15000 for quality body work and paint around here. Thats just labor. I agree with using a top notch restorer. Pay now or pay more later is usually the case.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: Rotisserie Restoration [Re: fireeng] #883468
12/19/10 09:36 PM
12/19/10 09:36 PM
SoCal
SoCal
And that's on a Rotisserie? Ok, it doesn't seem too bad. Would that include enlarging the Trans tunnel? Well, then again, I live in California so prices are a bit higher .
Re: Rotisserie Restoration [Re: MuuMuu101] #883469
12/19/10 09:41 PM
12/19/10 09:41 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Why not fab all the tunnel mods yourself ? Buy a good mig welder and have at it.
Just buy the metal you want and shape it to suit your needs.
Re: Rotisserie Restoration [Re: OzHemi] #883470
12/19/10 09:45 PM
12/19/10 09:45 PM
SoCal
SoCal
I would love to. I won't learn how to weld in college till probably next year when I join the SAE Formula team in college. I was thinking about it. I'm just trying to gather as much information and research sooo much so I can be efficient and not waste time or money later. But it would be fun. I would probably have to buy the whole transmission linkage first so I could measure everything. But then again I don't have any tools.
Re: Rotisserie Restoration [Re: OzHemi] #883471
12/19/10 09:48 PM
12/19/10 09:48 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Frankly, if you are going to undercoat the underside, are you sure you need to flip the car? Undercoat covers up a lot of ills. And a lot of detail work.
Master, again and still
Re: Rotisserie Restoration [Re: DaveRS23] #883472
12/19/10 09:55 PM
12/19/10 09:55 PM
SoCal
SoCal
Maybe I don't need it. It will be a show kind of car but I do want to drag race it once and try to autocross or road race it maybe once or twice a month.
Re: Rotisserie Restoration [Re: not_a_charger] #883473
12/19/10 09:56 PM
12/19/10 09:56 PM
Mid-Atlantic
Scatransit Offline
Scatransit  Offline
Mid-Atlantic
...A mediocre paint job will make the nice bodywork look like garbage.
And vise-versa...
[oo]======[oo]
Re: Rotisserie Restoration [Re: Scatransit] #883474
12/19/10 10:05 PM
12/19/10 10:05 PM
SoCal
SoCal
Good point.
Re: Rotisserie Restoration [Re: MuuMuu101] #883475
12/19/10 10:27 PM
12/19/10 10:27 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
These are just some thoughts, not meant as criticisms. I haven't seen a lot of "show cars" with undercoating. And undercoating on race cars would just seem to add needless weight and make future mods a little more difficult.
Re: Rotisserie Restoration [Re: DaveRS23] #883476
12/19/10 10:35 PM
12/19/10 10:35 PM
SoCal
SoCal
I just thought about that now. Undercoat is a no go. I think I will be fine with some normal body work. But thanks for your input
Re: Rotisserie Restoration [Re: MuuMuu101] #883477
12/20/10 12:02 AM
12/20/10 12:02 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Why not wait then until you have the transmission to go in the car (so you will know just what mods will be needed) and by then perhaps have the ability and tools to do the floor mods yourself ?
Not sure if cost is an issue to you, but imagine if you do the custom fab work yourself it will save a decent dollar and leave some extra for the rest of the body.
If it were me (and I have just done it this way myself..) I'd get the engine and trans in the car, get all the fab work done, and get it running and driving even so you can work all the bug out, then just pull the engine and trans and have the body done.
That way if you have some other holes to drill,lines ,wires,etc to run you will be able to do it all without worry of scratching new paint.
I've done a couple of pretty involved builds now, and did both of them that way...cars where completely running and driving then did paint and body last.
Perhaps just blow some primer over the iffy spots on your car now and just fabricate as you go.
Having the proper tools will make the job MUCH easier and go alot easier as well. I've been buying stuff I didn't have as I went and made for not only an easier project but more enjoyable as well. (for example...I built all of my own custom a/c lines and bought a crimp tool to build them all...)
Re: Rotisserie Restoration [Re: OzHemi] #883478
12/20/10 12:19 AM
12/20/10 12:19 AM
SoCal
SoCal
That's awesome! I was definitely thinking about installing interior last and I was thinking about getting the drivetrain first. I found a trans on eBay for $2500 (And that includes shipping). The Bellhousing is going to be around a couple hundred and then I am going to need the clutch pedals, shifters, etc. The engine with everything on it is almost $10k new. That's a lot to chew on just to prep in the car. Almost $15k. Not to mention in order to mount it, I want to install Reilly Motorsports alterktion and streetlynx suspension. Which is another $10k (Including a new rear end and driveshaft). Not to mention breaks will be another $1-3k. So I was thinking about restoring in this order: Suspension, drivetrain, body, interior. Or should I do interior then body since I will be making modifications to the trans tunnel? Thanks for the help .
Re: Rotisserie Restoration [Re: MuuMuu101] #883479
12/20/10 12:29 AM
12/20/10 12:29 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
In your budget...don't forget stuff like fuel system, cooling system,etc,etc then add a couple grand on for little stuff (I don't even want to think what I've spent on ARP stuff )
Oh, and if it were me...I'd do interior pretty much last, since you want to have the trans tunnel and shifter stuff all completely done before you start to think about console and what not. And you'll want the engine in place to you can plan out where to run all the wiring looms, etc.
I'm not a pro, but just been through it a couple times is all
Oh, and once I finish my Torana (which is just about there...) my next big project will be another Oz Mopar again
Here is my Torana I'm doing now...
And something else neat I did...
Not Mopars...just I think alot of the basic build progress and process is similar at least. (and I've had a bunch of Mopars too..just done these 2 things most currently)
And already have abit of a plan in mind for the Aussie Valiant build too coming next...
