Re: Rotisserie Restoration
[Re: MuuMuu101]
#883461
12/19/10 06:50 PM
12/19/10 06:50 PM
Posts: 20,032 Puttin' on the foil in Charles...
not_a_charger
Mr. Big Shot Moparts Moderator
You're going to spend the money to have the bodywork done on a rotisserie, but have a mechanic paint the car? Not that there aren't mechanics out there that also know how to paint, but why not get the body/paint done by the same folks? Also, your "What color should I paint my car" topic is in the General forum. ![](/ubbthreads/images/graemlins/thumbs.gif)
Earning every penny of that moderator paycheck.
DBAP
[Re: MuuMuu101]
#883463
12/19/10 08:05 PM
12/19/10 08:05 PM
not_a_charger
My point is that if you're going to go through the trouble and expense of having a body shop do a rotisserie job on the body and get the body nice and smooth, you'll likely come out ahead if you spend the money to have them paint it. Saving money on paint after spending big money on body isn't a wise decision. Enlarging the trans tunnel isn't a huge deal. If the mechanic can't do something relatively simple like that, I doubt he's got the skill to lay down a quality paint job. A mediocre paint job will make the nice bodywork look like garbage. ![](/ubbthreads/images/graemlins/Twocents.gif)
DBAP
[Re: MuuMuu101]
#883465
12/19/10 08:33 PM
12/19/10 08:33 PM
not_a_charger
There's no way anyone can give you an accurate cost for that work via the internet without the following:
1) a detailed description of exactly what body work needs to be done
2) pictures to accompany the description
3) Info on what parts need to be replaced and the cost of those parts
4) The prevailing labor, paint & material, and tax rates in your area
5) Are you going to paint it base/clear or single stage?
Doing the body and paint on a rotisserie, and doing a QUALITY job, will run you into the 5 figures easily.
DBAP
[Re: fireeng]
#883468
12/19/10 09:36 PM
12/19/10 09:36 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Between 7000 and 15000 for quality body work and paint around here. Thats just labor. I agree with using a top notch restorer. Pay now or pay more later is usually the case.
And that's on a Rotisserie? Ok, it doesn't seem too bad. Would that include enlarging the Trans tunnel? Well, then again, I live in California so prices are a bit higher . ![](/ubbthreads/images/graemlins/fan.gif)
[Re: MuuMuu101]
#883469
12/19/10 09:41 PM
12/19/10 09:41 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
This will be a long 4-6 year project I hope to do mostly myself.
Why not fab all the tunnel mods yourself ? Buy a good mig welder and have at it. ![](/ubbthreads/images/graemlins/weld.gif) Just buy the metal you want and shape it to suit your needs.
[Re: Scatransit]
#883474
12/19/10 10:05 PM
12/19/10 10:05 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
[Re: MuuMuu101]
#883475
12/19/10 10:27 PM
12/19/10 10:27 PM
Posts: 12,295 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
These are just some thoughts, not meant as criticisms. I haven't seen a lot of "show cars" with undercoating. And undercoating on race cars would just seem to add needless weight and make future mods a little more difficult.
Master, again and still
[Re: DaveRS23]
#883476
12/19/10 10:35 PM
12/19/10 10:35 PM
Posts: 12,375 SoCal
MuuMuu101
SoCal
I just thought about that now. Undercoat is a no go. I think I will be fine with some normal body work. But thanks for your input ![](/ubbthreads/images/graemlins/smile.gif)
[Re: MuuMuu101]
#883477
12/20/10 12:02 AM
12/20/10 12:02 AM
OzHemi
Garden Grove, CA
I would love to. I won't learn how to weld in college till probably next year when I join the SAE Formula team in college. I was thinking about it. I'm just trying to gather as much information and research sooo much so I can be efficient and not waste time or money later. But it would be fun. I would probably have to buy the whole transmission linkage first so I could measure everything. But then again I don't have any tools.
Why not wait then until you have the transmission to go in the car (so you will know just what mods will be needed) and by then perhaps have the ability and tools to do the floor mods yourself ? Not sure if cost is an issue to you, but imagine if you do the custom fab work yourself it will save a decent dollar and leave some extra for the rest of the body.
If it were me (and I have just done it this way myself..) I'd get the engine and trans in the car, get all the fab work done, and get it running and driving even so you can work all the bug out, then just pull the engine and trans and have the body done. That way if you have some other holes to drill,lines ,wires,etc to run you will be able to do it all without worry of scratching new paint.
I've done a couple of pretty involved builds now, and did both of them that way...cars where completely running and driving then did paint and body last.
Perhaps just blow some primer over the iffy spots on your car now and just fabricate as you go.
Having the proper tools will make the job MUCH easier and go alot easier as well. I've been buying stuff I didn't have as I went and made for not only an easier project but more enjoyable as well. (for example...I built all of my own custom a/c lines and bought a crimp tool to build them all...)
[Re: OzHemi]
#883478
12/20/10 12:19 AM
12/20/10 12:19 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
That's awesome! I was definitely thinking about installing interior last and I was thinking about getting the drivetrain first. I found a trans on eBay for $2500 (And that includes shipping). The Bellhousing is going to be around a couple hundred and then I am going to need the clutch pedals, shifters, etc. The engine with everything on it is almost $10k new. That's a lot to chew on just to prep in the car. Almost $15k. Not to mention in order to mount it, I want to install Reilly Motorsports alterktion and streetlynx suspension. Which is another $10k (Including a new rear end and driveshaft). Not to mention breaks will be another $1-3k. So I was thinking about restoring in this order: Suspension, drivetrain, body, interior. Or should I do interior then body since I will be making modifications to the trans tunnel? Thanks for the help .
[Re: MuuMuu101]
#883479
12/20/10 12:29 AM
12/20/10 12:29 AM
OzHemi
Garden Grove, CA
In your budget...don't forget stuff like fuel system, cooling system,etc,etc then add a couple grand on for little stuff ![](/ubbthreads/images/graemlins/laugh2.gif) (I don't even want to think what I've spent on ARP stuff ![](/ubbthreads/images/graemlins/shock.gif) ) Oh, and if it were me...I'd do interior pretty much last, since you want to have the trans tunnel and shifter stuff all completely done before you start to think about console and what not. And you'll want the engine in place to you can plan out where to run all the wiring looms, etc. ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) I'm not a pro, but just been through it a couple times is all ![](/ubbthreads/images/graemlins/laugh2.gif) Oh, and once I finish my Torana (which is just about there...) my next big project will be another Oz Mopar again Here is my Torana I'm doing now... And something else neat I did... Not Mopars...just I think alot of the basic build progress and process is similar at least. (and I've had a bunch of Mopars too..just done these 2 things most currently) And already have abit of a plan in mind for the Aussie Valiant build too coming next...
