This is my
. The stock factory front clutches was a tan or a brown color and the rear clutches were black or a very dark gray. Front band was also a tan or brown color. I build and have built trannies all my adult life. And the after market clutches of the high performance nature are; front clutches are either black, dark gray, red, or even blue. Rear clutches are once again a black or dark gray. Normally the front band is a red one, The rear band is always the black or dark gray color in both HP and stock. That's my
and I'm sure someone else may tell you different, that's the way it works on Moparts,
I loved using the 904 in my old car. 10:40s at 3300 lbs W/brake. Good Luck, cool project you have.
WWW.Coan Racing.com
