TO4B ??? #882606
12/17/10 03:55 PM
12/17/10 03:55 PM
O'Fallon,IL.
70RTRacer Offline OP
O'Fallon,IL.
I recently acquired two TO4B turbos in a trade and was thinking about building something for them. Are these good for a twin turbo setup? What cubic inch will they support? Any info would help. I would like to stay with a big block.
Re: TO4B ??? [Re: 70RTRacer] #882607
12/17/10 05:24 PM
12/17/10 05:24 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
T04B is a bit like saying you have a 440. Doesnt tell you any of the meaningful information. What MM are the inducer and exducer of each wheel? What is the A/R rating on the turbine housing?
With that info we will know alot more.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: TO4B ??? [Re: 70RTRacer] #882608
12/17/10 05:49 PM
12/17/10 05:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A pair of those with 60-1 compressors and P-trim turbines under .96 or larger housings are great for a mild 440 build. They can support more than 500 hp each.
If you've got the dinky stuff that came on 4 bangers then it's a different story.
- Stu Harmon
Re: TO4B ??? [Re: feets] #882609
12/17/10 06:16 PM
12/17/10 06:16 PM
O'Fallon,IL.
O'Fallon,IL.
The compressor side is A/R .60 and the exhaust side is A/R .96. Is that what you are asking FEETS? They were on a big block chevy. I think a 468.
Re: TO4B ??? [Re: 70RTRacer] #882610
12/17/10 07:32 PM
12/17/10 07:32 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
More than likely they will way to small if it has anything to do with the car in your avatar.....depending on their size they would be ok on a decent smallblock..but not a big block.
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: TO4B ??? [Re: instigator] #882611
12/17/10 08:44 PM
12/17/10 08:44 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
They would work well on a street application or a race setup that you are not trying to run 9's. I have a pair of 57mm T04E's on a stock 383 (stock cam as well) and they pushed my 3200lb car to 94mph (1/8 mile) with 2.56 gear
Re: TO4B ??? [Re: 70RTRacer] #882612
12/18/10 12:33 AM
12/18/10 12:33 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Those would be perfect for a 700 to 800 hp big block. Lotsa fun on the street too!
- Stu Harmon
Re: TO4B ??? [Re: feets] #882613
12/20/10 02:17 PM
12/20/10 02:17 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
There's a link in here that might help you ID your those turbos.
https://board.moparts.org/ubbthreads/show...e=3#Post6260207
Re: TO4B ??? [Re: Fury Fan] #882614
12/20/10 03:54 PM
12/20/10 03:54 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
