Re: TO4B ???
[Re: 70RTRacer]
#882607
12/17/10 05:24 PM
12/17/10 05:24 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
T04B is a bit like saying you have a 440. Doesnt tell you any of the meaningful information. What MM are the inducer and exducer of each wheel? What is the A/R rating on the turbine housing?
With that info we will know alot more.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: TO4B ???
[Re: 70RTRacer]
#882608
12/17/10 05:49 PM
12/17/10 05:49 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
A pair of those with 60-1 compressors and P-trim turbines under .96 or larger housings are great for a mild 440 build. They can support more than 500 hp each.
If you've got the dinky stuff that came on 4 bangers then it's a different story.
Re: TO4B ???
[Re: 70RTRacer]
#882610
12/17/10 07:32 PM
12/17/10 07:32 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
More than likely they will way to small if it has anything to do with the car in your avatar.....depending on their size they would be ok on a decent smallblock..but not a big block.
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
