SCE ICS Titan Copper Head Gaskets #882306
12/17/10 11:04 AM
12/17/10 11:04 AM
western pennsylvania
b1dartsport Offline OP
Thinking about going to the Titan ics gaskets. Been using the cometics and sick and tired of them leaking,weeping ect. Anybody using the new copper head gaskets with built in O ring and sealant?
Re: SCE ICS Titan Copper Head Gaskets [Re: b1dartsport] #882307
12/17/10 01:49 PM
12/17/10 01:49 PM
SoCal
Brian Hafliger Offline
SoCal
Yes they work good but the beads around the water holes are never correct especially for Indy heads.
I order them without the beads, and then silicone around the water holes of the head AND the block and then your good to go.
Brian
Brian Hafliger
Re: SCE ICS Titan Copper Head Gaskets [Re: b1dartsport] #882308
12/17/10 02:09 PM
12/17/10 02:09 PM
I have used them on several street motors(blown hemis and wedges) and race motors, no problems at all
Re: SCE ICS Titan Copper Head Gaskets [Re: Brian Hafliger] #882309
12/17/10 02:55 PM
12/17/10 02:55 PM
Brian
I have the 360-2 indys 230cc. Brian,do you think it would be difficult to fix them even with the beads on? I have a chance to buy an unused set very cheap.
Re: SCE ICS Titan Copper Head Gaskets [Re: b1dartsport] #882310
12/17/10 03:30 PM
12/17/10 03:30 PM
Vacherie, Louisiana
SuperStocker Offline
super gas
super gas
Vacherie, Louisiana
FWIW, I used these before with the beads and just sealed the block and heads with sealer. They then worked great and hadn't had any other trouble with them. Just go ahead and seal the water ports and you'll be fine.
Re: SCE ICS Titan Copper Head Gaskets [Re: SuperStocker] #882311
12/17/10 06:26 PM
12/17/10 06:26 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Are these gaskets reusable?
Re: SCE ICS Titan Copper Head Gaskets [Re: SuperStocker] #882312
12/18/10 12:31 AM
12/18/10 12:31 AM
SoCal
SoCal
Brian Hafliger
Re: SCE ICS Titan Copper Head Gaskets [Re: mac56] #882313
12/18/10 07:52 AM
12/18/10 07:52 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Yes, until the o-ring groove starts widening due to detonation. You will also see some blackness (carbon deposits)between adjacent cylinders when this happens.
8.30's @3400 lbs
Re: SCE ICS Titan Copper Head Gaskets [Re: Mike Swann] #882314
12/18/10 04:30 PM
12/18/10 04:30 PM
Thanks for the info guys, I just picked up the new gaskets, looks like a piece of cake to seal em up -Randy
