Re: Slant 6 manual steering box same as a V8's? [Re: A70Runner] #882202
12/20/10 10:52 AM
12/20/10 10:52 AM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
I've got a box from a 63 B-Body /6 and it has the rib just like in the pic?
Re: Slant 6 manual steering box same as a V8's? [Re: A70Runner] #882203
12/20/10 03:01 PM
12/20/10 03:01 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
It shows it has the bearings. The ones with bushings don't have that hump.
Show me some factory documentation that proves this to be true. And while you're at it, be sure to avoid engine blocks that have had their cores changed too many times based on that number cast into the side of the block.
Re: Slant 6 manual steering box same as a V8's? [Re: @#$%&*!] #882204
12/20/10 09:10 PM
12/20/10 09:10 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
do many of the bushed boxes go bad?is there that much of a differance to be concerned about on a street car?
Re: Slant 6 manual steering box same as a V8's? [Re: mcmopars] #882205
12/20/10 10:19 PM
12/20/10 10:19 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
I'd say no. As long as the box is clean (internally), lubed, and adjusted properly you won't know the difference. Except for the 20:1 worm gear, there aren't any new parts available for these except for bushings, bearings and gaskets. A rebuild is basically a good cleaning, assembly, and adjustment to specs. You can do this at home but the cleaning can be tough if the grease is dried out (common).
FWIW, I have a '74 Dart Sport 225 car and the gear box has the 'V8 bearing lump' on it and the box that came with my 318 '68 Barracuda doesn't have the lump. I don't think they had a different die casting for gears that would get a bearing, it was just machined differently. You can ream out a bushed housing and install a bearing if you want.
Re: Slant 6 manual steering box same as a V8's? [Re: @#$%&*!] #882206
12/20/10 11:10 PM
12/20/10 11:10 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
I looked at about 20 of my cores today...in parts cars and on the rack.All the A Body six bangers are smooth.V-8s and 6 B's with manual have the rib.
"Long Live Mopars"
Re: Slant 6 manual steering box same as a V8's? [Re: Furyman] #882207
12/21/10 12:55 AM
12/21/10 12:55 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Slant 6 manual steering box same as a V8's? [Re: @#$%&*!] #882208
12/21/10 06:15 AM
12/21/10 06:15 AM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
Because that is they way Chrysler Engineering steering and suspension did it that way. The bushing don't last like the bearing.
Re: Slant 6 manual steering box same as a V8's? [Re: Cuda67] #882209
12/21/10 10:50 AM
12/21/10 10:50 AM
At a gas station near you
badblack68 Offline
badblack68  Offline
Last question for now, how much lube do you put in the box?
Re: Slant 6 manual steering box same as a V8's? [Re: badblack68] #882210
12/21/10 03:55 PM
12/21/10 03:55 PM
Everywhere
moparboy76 Offline
moparboy76  Offline
Everywhere
until she slides real easy! LMFAO Sorry guys had to do it!
Re: Slant 6 manual steering box same as a V8's? [Re: @#$%&*!] #882211
12/21/10 05:23 PM
12/21/10 05:23 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
I doubt the factory would have any documentation on this as a outside vender built the boxes. I am sure the housings look the same but they are diffrent casting for the bearings. Why would you send some boxes out for extra machine work if you didn't need to? But I just looked at my steering box that I know has the bushings in it because I rebuilt it myself and It does not have the ridge in the case. With that and what other people have posted it sure sounds like there is something to this ridge, Almost like counting bands on the input shaft of a T-10 to know what ratio gears are in it. I am sure there are other suttle diffrences in other parts to tell internal diffrences.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
Re: Slant 6 manual steering box same as a V8's? [Re: badblack68] #882212
12/21/10 05:25 PM
12/21/10 05:25 PM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
I filled mine with Mobil 460 wheel bearing grease until I couldn't put anymore in the fill hole. Then I waited a day for it to settle and did it again.
Re: Slant 6 manual steering box same as a V8's? [Re: badblack68] #882213
12/21/10 05:56 PM
12/21/10 05:56 PM
RapidRobert Online content
RapidRobert  Online Content
Dont know the exact amt but I like to pretty much cover the worm/sector (after going from lock to lock) & leave a little bit of air space for expansion
Re: Slant 6 manual steering box same as a V8's? [Re: SomeCarGuy] #882214
12/21/10 06:11 PM
12/21/10 06:11 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
I ordered one w/ beaings from a JY out west, had to be a decade or more ago. I called and complained that it was a bushed one, not what I ordered. They said send it back, will refund. No refund.
If I ever find any reason to pass through Idaho I will stop.
They claimed it came from a 318 car. No telling what the deal was there. Plenty of variables.
Who and where in Idaho was this?
Re: Slant 6 manual steering box same as a V8's? [Re: A70Runner] #882215
12/21/10 07:07 PM
12/21/10 07:07 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
I'd leave an air pocket or you'll likely have it seeping out due to thermal expansion. Those steering gears aren't vented.
Re: Slant 6 manual steering box same as a V8's? [Re: Furyman] #882216
12/22/10 12:08 AM
12/22/10 12:08 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Pretty much what I found with mine.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
