Slant 6 manual steering box same as a V8's? #882182
12/16/10 10:42 PM
12/16/10 10:42 PM
West Central Wisconsin
Exciter72 Offline OP
Seeing some manual steering boxs being sold as V8. I was planning on re-using the slant six manual steering box on my V8 swap project. Are they the same?
Tony
Re: Slant 6 manual steering box same as a V8's? [Re: Exciter72] #882183
12/17/10 12:07 AM
12/17/10 12:07 AM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
IIRC, on v8 cars, the manual boxes have needle bearings, where the /6 cars have bronze(oilite)? bushings. how/why this got past the bean counters i don't know.
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Slant 6 manual steering box same as a V8's? [Re: Exciter72] #882184
12/17/10 01:36 AM
12/17/10 01:36 AM
Chesterfield, MIch
Cuda67 Offline
super street
Cuda67  Offline
super street
Chesterfield, MIch
See the rib that is behind the fill hole that goes a little less than half way back. That is with the bearings. If that rib is not there it's a bushing and you don't want that one. Stick with the bearing type.
The information came from the steering and suspension department at Chrysler Enginering. I worked at engineering form 36-1/2 years. The bushing ones (without the lump) wear out quicker. A-body 6 cyl are the only ones that got them.
If you want to run it, thats your choice. The siz and wt are the same in both cases.
I won't!!
Re: Slant 6 manual steering box same as a V8's? [Re: Cuda67] #882185
12/17/10 01:57 AM
12/17/10 01:57 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Nice observation. Good to know. This sort of thing is helpful... thank you.
Re: Slant 6 manual steering box same as a V8's? [Re: Kern Dog] #882186
12/17/10 01:03 PM
12/17/10 01:03 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Not to go off topic but what is used for lubricant inside a manual steering box?
Re: Slant 6 manual steering box same as a V8's? [Re: Cuda67] #882187
12/17/10 01:40 PM
12/17/10 01:40 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
great info
Re: Slant 6 manual steering box same as a V8's? [Re: Flite_727] #882188
12/17/10 01:41 PM
12/17/10 01:41 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
Same logic that /6--small V8's have lesser, small brakes. Chrysler ain't the only one--common of Ferd, Gee eMM, too
Re: Slant 6 manual steering box same as a V8's? [Re: Exciter72] #882189
12/17/10 07:30 PM
12/17/10 07:30 PM
Everywhere
moparboy76 Offline
moparboy76  Offline
Everywhere
I know from presonal experience that the /6 box will steer a 360 quite fine in a 76 valiant cloned over to a 360. We left pretty much everything stock except for the engine. Yes i know alot fo things should have been changed but te car was built on a very low budget darn near didnt have a budget broke as a church mouse!
Now however my curiosity has been sparked. Is the v-8 box smaller or lighter? Does it make a large difference in the handling of the car? whats the pro's and con's im sure the original poster might like to know as well?
Re: Slant 6 manual steering box same as a V8's? [Re: moparboy76] #882190
12/17/10 07:51 PM
12/17/10 07:51 PM
Either one will work fine for you. I go w Ehrenbergs rec of MP hi temp wheel bearing grease mixed w iirc a bit of gear lube (The combo should be in the Mopar Action archives).
Re: Slant 6 manual steering box same as a V8's? [Re: RapidRobert] #882191
12/17/10 09:52 PM
12/17/10 09:52 PM
badblack68 Offline
badblack68  Offline
All my factory service maanual says is to use steering gear lubricant with no reference to what that lubricant is. What does everyone else use or does someone have ebergs recipe?
Re: Slant 6 manual steering box same as a V8's? [Re: badblack68] #882192
12/18/10 03:10 AM
12/18/10 03:10 AM
ebergs recipe?
1 tube of MP high temp lube 4318046, heat it in a saucepan and add 2 or 3 oz of SAE 90 gear oil, enough to make a pourable mix. From Feb 1999 Mopar Action
Re: Slant 6 manual steering box same as a V8's? [Re: RapidRobert] #882193
12/18/10 10:57 AM
12/18/10 10:57 AM
Thanks everyone for the great information
I assume that the physical demensions are the same as far as header clearences and steering wheel shaft alignment?
Re: Slant 6 manual steering box same as a V8's? [Re: RapidRobert] #882194
12/18/10 11:02 AM
12/18/10 11:02 AM
85086
moparpollack Online penguin-006
Lil Herman
moparpollack  Online Penguin-006
Lil Herman
85086
ebergs recipe?
It also said something about chopped walnuts too.
Re: Slant 6 manual steering box same as a V8's? [Re: moparpollack] #882195
12/18/10 11:41 AM
12/18/10 11:41 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I was told the orig fluid was Marfax 250 weight oil very thick stuff .
Re: Slant 6 manual steering box same as a V8's? [Re: moparpollack] #882196
12/18/10 12:06 PM
12/18/10 12:06 PM
Purposely left out to avoid copyright infringement. Rick gets pretty bent out of shape over that. I got a tube of it (the green stuff) but haven't got around to mixing a batch yet. I've opened boxes where the grease was too thick and was not in contact w the mating surfaces and the oil mix would take care of that
Re: Slant 6 manual steering box same as a V8's? [Re: Cuda67] #882197
12/19/10 09:11 PM
12/19/10 09:11 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I don't believe that at all. The bushing or bearing is at the other end of the case, at the sector output. Why would that little lump have any connection?
Re: Slant 6 manual steering box same as a V8's? [Re: @#$%&*!] #882198
12/20/10 01:38 AM
12/20/10 01:38 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
So are the bearing units worth anything as cores? Have some that are worn that I was going to throw out.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Slant 6 manual steering box same as a V8's? [Re: @#$%&*!] #882199
12/20/10 01:41 AM
12/20/10 01:41 AM
moparmarks Offline
moparmarks  Offline
I'm checking out mine tomorrow. Have some from V8's, 6's, A, B and E's
I thought A-bodies got the bushed ones and B/E got the bearing ones.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Slant 6 manual steering box same as a V8's? [Re: moparmarks] #882200
12/20/10 02:48 AM
12/20/10 02:48 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I ordered one w/ beaings from a JY out west, had to be a decade or more ago. I called and complained that it was a bushed one, not what I ordered. They said send it back, will refund. No refund.
If I ever find any reason to pass through Idaho I will stop.
They claimed it came from a 318 car. No telling what the deal was there. Plenty of variables.
Re: Slant 6 manual steering box same as a V8's? [Re: @#$%&*!] #882201
12/20/10 08:10 AM
12/20/10 08:10 AM
Mooresville, NC
A70Runner Offline
A70Runner  Offline
Mooresville, NC
It shows it has the bearings. The ones with bushings don't have that hump.
"People Think I'm Insane Because I Am Frowning All The Time" Black Sabbath
