Re: Cowl Vent Paint Prep
[Re: Tomsecks]
#882167
12/17/10 09:59 AM
12/17/10 09:59 AM
Posts: 2,632 Nashville, TN
MOPARMIKE69
Nashville, TN
Wire wheel on a drill or die grinder. Be sure and wear eye protection.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: Tomsecks]
#882168
12/17/10 11:36 AM
12/17/10 11:36 AM
Posts: 401 Ohio, USA
Dr-Dave2
Ohio, USA
Make your kids do it! my daughter has helped me prep 5 allover repaints, getting pretty good at it too. but seriously the fine wire brush on a drill will get you started, followed by folded over sandpaper then 3M dark red scuff pad and oh-yeah a couple of hours of time
[Re: MOPARMIKE69]
#882169
12/18/10 02:00 AM
12/18/10 02:00 AM
Posts: 1,572 Jacksonville Florida
elitecustombody
How about a 36 grit disc on a grinder?
OP is looking for advice to prep,not strip
Red scuff pads always works just fine
[Re: Tomsecks]
#882170
12/19/10 03:23 AM
12/19/10 03:23 AM
Posts: 3,319 Chicago Burbs
sthemi
Chicago Burbs
I will add to remember to clean the area out with high pressure air hose. At least 5 seperate times, throughly at every angle possible. That ia a giant trap for crud to wreck a fresh paint job.. BTW, I used a paint stick with scuffin pads on mine...
