What Hp do you think my 493 indy head motor makes?
#882043
12/16/10 06:57 PM
12/16/10 06:57 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
What kind of power do you guys think i am making ? Here is the setup 493 rb block zero deck ross pistons compression is 10.88 to 1 static compression is 8.65 to 1 dynamic Heads: Indy sr with bowl port and intake ports matched .And competition valve job .
Cam :comp solid Roller .252 .260 dur @.050 .630 gross lift lobe separation 108 cam installed at 104c/l
Intake: M1 single plane ported Carb; MightyDemon 850 anular malory hyfire VI digital ignition 36 deg total tti 2 to 2 1/8 step headers
carb is tuned to 12.9 a/f ratio with lm2 meter at full throttle . on pump 93 octane gas what kind of numbers do you think i could be putting down ? Car is 69 charger with hemi 4spd and 4:10 gear approx weight 3800
1969 Dodge Charger
1969 Dodge Superbee
Re: What Hp do you think my 493 indy head motor makes?
[Re: cjs69mope]
#882045
12/16/10 07:07 PM
12/16/10 07:07 PM
620 hp.
#882047
12/16/10 07:12 PM
12/16/10 07:12 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
640 but i deducted 10 for the yellow paint
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
#882048
12/16/10 07:13 PM
12/16/10 07:13 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
This is real similar to my 499 other then mine has stage v1 heads and 12.5-1 compression and my cam is 272/275 @ 50 with .620 lift and a 1050 dominator. I think mine makes around 620 h.p. E.T. in sig. car weighs 3740. 8" 5000 converter.3.91's 28" tires
67' charger 499 RB
10.57 at 127
[Re: dennismopar73]
#882049
12/16/10 07:18 PM
12/16/10 07:18 PM
Posts: 614 Michigan
Get-X
I was thinking 600 hp and 1850 ft lbs of torque It's about the same color as my Caterpillar All kidding aside, I'd say 625-650ish at the crank
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: dragram440]
#882050
12/16/10 07:24 PM
12/16/10 07:24 PM
Posts: 587 IL . usa
cjs69mope
IL . usa
Ok thanks i know most people dont like yellow but than the see mine and say "I would never have a yellow car but yours makes me want to change my mind its hott" what ever that was the idea to stand out !
1969 Dodge Charger
1969 Dodge Superbee
[Re: dennismopar73]
#882054
12/16/10 07:58 PM
12/16/10 07:58 PM
Posts: 941 Texas, USA
ChrgrCuda
Texas, USA
I love yellow! I'm currently putting my 69 Charger back together with a similar combo. I would love to see more pic's pretty please and some more info on the car itself. Here is my combo currently going together: 505 '77 440 block .030 over RPM crank 4.25 K-1 6.8 Rods Probe 20 cc inverted dome pistons Indy Lil EZ 295cc heads worked over by Compuflow Solid Roller spec'd by Compuflow Indy 2-D prepped by Compuflow. Nick said it should come in at about 10.8:1 compression. I was shooting for 620-650 horses. Guess I'll have to wait and see.
68 Cuda Notchback [Email]10.86@120[/Email]
69 Charger R/T 440/505
2009 Challenger SRT8
[Re: MIKES_DUSTER]
#882056
12/16/10 08:01 PM
12/16/10 08:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Im NO expert but I dont think you can make over 600hp with that compression and that big cam. Bump that compression up and then I can see it.
Im SURE ill hear alot of negativity!!!! LOL
I dont think so either... with the static and dynamic being low... about 575-580.... JMO
[Re: bonefish]
#882061
12/16/10 08:05 PM
12/16/10 08:05 PM
ChrgrCuda
Texas, USA
Your car looks great. The biggest problem I see is that you didn't post anymore pic's, especially with the hood closed. Did you post on DodgeCharger dot com?
[Re: cjs69mope]
#882062
12/16/10 08:26 PM
12/16/10 08:26 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i can only relay what i'd expect it to make on the dyno i use, which has been extremely close when compared to MPH at the track. your likely to make between 550-565 honest HP IMO. that's a small cam with unported heads but yet a ported intake. i'm not too concerned about the C/R or the carb, that's a pretty typical street type build for pump gas. in the end it makes whatever it makes. if it runs good enough for you, then it makes all it needs to make regardless of the actual number. run it down the 1/4 mile once or twice and you'll pretty much know what it really makes.
machine shop owner and engine builder
