What Hp do you think my 493 indy head motor makes? #882043
12/16/10 06:57 PM
12/16/10 06:57 PM
IL . usa
cjs69mope Offline OP
IL . usa
What kind of power do you guys think i am making ?
Here is the setup
493 rb block zero deck
ross pistons compression is 10.88 to 1 static
compression is 8.65 to 1 dynamic
Heads: Indy sr with bowl port and intake ports matched .And competition valve job .
Cam :comp solid Roller .252 .260 dur @.050
.630 gross lift
lobe separation 108
cam installed at 104c/l
Intake: M1 single plane ported
Carb; MightyDemon 850 anular
malory hyfire VI digital ignition 36 deg total
tti 2 to 2 1/8 step headers
carb is tuned to 12.9 a/f ratio with lm2 meter at full throttle . on pump 93 octane gas
what kind of numbers do you think i could be putting down ?
Car is 69 charger with hemi 4spd and 4:10 gear approx weight 3800
1969 Dodge Charger 1969 Dodge Superbee
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882044
12/16/10 07:01 PM
12/16/10 07:01 PM
IL . usa
IL . usa
another pic
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882045
12/16/10 07:07 PM
12/16/10 07:07 PM
620 hp.
Re: What Hp do you think my 493 indy head motor makes? #882046
12/16/10 07:10 PM
12/16/10 07:10 PM
ill
dennismopar73 Offline
ill
i dono its yellow
i'm scared to tell
(590-625)
flywheel
Re: What Hp do you think my 493 indy head motor makes? #882047
12/16/10 07:12 PM
12/16/10 07:12 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
640 but i deducted 10 for the yellow paint
Re: What Hp do you think my 493 indy head motor makes? #882048
12/16/10 07:13 PM
12/16/10 07:13 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
This is real similar to my 499 other then mine has stage v1 heads and 12.5-1 compression and my cam is 272/275 @ 50 with .620 lift and a 1050 dominator. I think mine makes around 620 h.p. E.T. in sig. car weighs 3740. 8" 5000 converter.3.91's 28" tires
67' charger 499 RB 10.57 at 127
Re: What Hp do you think my 493 indy head motor makes? [Re: dennismopar73] #882049
12/16/10 07:18 PM
12/16/10 07:18 PM
Get-X Offline
Get-X  Offline
I was thinking 600 hp and 1850 ft lbs of torque It's about the same color as my Caterpillar
All kidding aside, I'd say 625-650ish at the crank
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: What Hp do you think my 493 indy head motor makes? [Re: dragram440] #882050
12/16/10 07:24 PM
12/16/10 07:24 PM
IL . usa
IL . usa
Ok thanks i know most people dont like yellow but than the see mine and say "I would never have a yellow car but yours makes me want to change my mind its hott" what ever that was the idea to stand out !
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882051
12/16/10 07:42 PM
12/16/10 07:42 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Im NO expert but I dont think you can make over 600hp with that compression and that big cam. Bump that compression up and then I can see it.
Im SURE ill hear alot of negativity!!!! LOL
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882052
12/16/10 07:50 PM
12/16/10 07:50 PM
ill
ill
i was just making fun sorry
i think its beautiful car
my nephew has a yellow challenger
quads out the hood look great to
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882053
12/16/10 07:53 PM
12/16/10 07:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
unported heads/low compression 560-570 on a good day
Re: What Hp do you think my 493 indy head motor makes? [Re: dennismopar73] #882054
12/16/10 07:58 PM
12/16/10 07:58 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
I love yellow! I'm currently putting my 69 Charger back together with a similar combo. I would love to see more pic's pretty please and some more info on the car itself.
Here is my combo currently going together:
505
'77 440 block .030 over
RPM crank 4.25
K-1 6.8 Rods
Probe 20 cc inverted dome pistons
Indy Lil EZ 295cc heads worked over by Compuflow
Solid Roller spec'd by Compuflow
Indy 2-D prepped by Compuflow.
Nick said it should come in at about 10.8:1 compression. I was shooting for 620-650 horses. Guess I'll have to wait and see.
68 Cuda Notchback [Email]10.86@120[/Email] 69 Charger R/T 440/505 2009 Challenger SRT8
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882055
12/16/10 08:00 PM
12/16/10 08:00 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Guess im a little different. I think the cam is a bit o the small side and the carb size too. Still with sr's and thoes cubes i'd guess in the 650hp range. Should be a heck of a lot of fun! Save some dough for new skins!
Damon
Re: What Hp do you think my 493 indy head motor makes? [Re: MIKES_DUSTER] #882056
12/16/10 08:01 PM
12/16/10 08:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont think so either... with the static and
dynamic being low... about 575-580.... JMO
Re: What Hp do you think my 493 indy head motor makes? [Re: Quicktree] #882057
12/16/10 08:02 PM
12/16/10 08:02 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Re: What Hp do you think my 493 indy head motor makes? [Re: Quicktree] #882058
12/16/10 08:02 PM
12/16/10 08:02 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882059
12/16/10 08:02 PM
12/16/10 08:02 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i dont like yellow either but i think that car looks great in yellow.
Re: What Hp do you think my 493 indy head motor makes? [Re: bonefish] #882060
12/16/10 08:04 PM
12/16/10 08:04 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
hey Quick thats scary
Re: What Hp do you think my 493 indy head motor makes? [Re: bonefish] #882061
12/16/10 08:05 PM
12/16/10 08:05 PM
Texas, USA
ChrgrCuda Offline
ChrgrCuda  Offline
Texas, USA
Your car looks great. The biggest problem I see is that you didn't post anymore pic's, especially with the hood closed. Did you post on DodgeCharger dot com?
Re: What Hp do you think my 493 indy head motor makes? [Re: cjs69mope] #882062
12/16/10 08:26 PM
12/16/10 08:26 PM
Delray beach, Florida
P
Performance Only Offline
P
i can only relay what i'd expect it to make on the dyno i use, which has been extremely close when compared to MPH at the track. your likely to make between 550-565 honest HP IMO.
that's a small cam with unported heads but yet a ported intake. i'm not too concerned about the C/R or the carb, that's a pretty typical street type build for pump gas. in the end it makes whatever it makes. if it runs good enough for you, then it makes all it needs to make regardless of the actual number.
run it down the 1/4 mile once or twice and you'll pretty much know what it really makes.
machine shop owner and engine builder
