New Compressor Locked up
#88199
07/13/08 08:44 PM
07/13/08 08:44 PM
Posts: 2,852 Dallas, TX
70challrtse
super gas
super gas
Dallas, TX
We installed a new compressor in my 81 Imperial and everything worked fine for a couple of days - but then today the AC wasn't blowing cold and the engine stopped. Some green fluid is coming out of the top of the compressor; not a lot, just a little. Shut the AC off and the car ran fine. Any ideas? Did I get a bad compressor? I bought a new one, not a remanufactured. Thanks.
Re: New Compressor Locked up
[Re: stumpy]
#88201
07/13/08 09:30 PM
07/13/08 09:30 PM
70challrtse
super gas
super gas
Dallas, TX
How much freon did you install.
About 1.5 cans.
[Re: 70challrtse]
#88202
07/13/08 09:58 PM
07/13/08 09:58 PM
Posts: 8,143 New Mexico
UCUDANT
Troll Hunter
Troll Hunter
New Mexico
Did you add oil? Was it in the compressor? Was this a conversion?
The green fluid sounds like the die added for leak detection
My Duster called for 2 lbs 12 oz of R12
When you convert to 134A it takes less but you put about 18oz?
[Re: 70challrtse]
#88203
07/13/08 10:05 PM
07/13/08 10:05 PM
Did the previous comp. seize-up too? Metal can be pumped thru system. Did you raplace rec/drier? Did you add proper amount of oil to system? Modern a/c comp. do not have a "crankcase" and the only lube they get is oil in the freon.
[Re: UCUDANT]
#88205
07/13/08 10:38 PM
07/13/08 10:38 PM
The compressor came dry and required oil. I put about 6 oz in the compressor and changed the dryer. I felt like if it needed more oil I could add a can of oil charge. I have never done a converstion but this one had been done some years back. Several people said use the green oil (can't remember the exact name) instead of PAG. Not sure that was a good idea but the experts said that would help with any misture or residual oil in the system. I could never get the system below 25 on the low side and it frankly wouldn't take any additional Freon. I was getting 47 degrees on the interior vents so I figured we were going the right way. Not sure what happened to cause the compressor to lock up except maybe it didn't like the oil.
The compressor was brand new so I am sure we can get it replaced...
#88206
07/14/08 07:46 AM
07/14/08 07:46 AM
70challrtse
super gas
super gas
Dallas, TX
[Re: 70challrtse]
#88207
07/14/08 09:38 AM
07/14/08 09:38 AM
Posts: 1,253 Slidell, LA
Ronnman
Slidell, LA
Well based on the old thread some of the questions we asked were never anwsered. Did you flush the system out? What comprossor make and model? Did you replaced the drier? Sounds like an oil related problem if the compressor tag said use PAG and you used another oil without a proper system flush. Ron Old thread https://board.moparts.org/ubbthreads/show...rue#Post4525095
