Re: Indy maxx block max bore ?
[Re: julian2007]
#881927
12/16/10 06:21 PM
12/16/10 06:21 PM
Posts: 2,644 North Carolina
sasquatch
North Carolina
It depends on what sleeves are in it. They use different sleeves for what bore size is ordered. You might want to call them. TOdd
[Re: bigtimeauto]
#881929
12/16/10 11:05 PM
12/16/10 11:05 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Nope, they have different sleeves.Todd and I been thru this before.
RIP Monte Smith
[Re: CompWedgeEngines]
#881930
12/17/10 12:26 AM
12/17/10 12:26 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I know they do offer a thicker sleeve to go past 4.500 but then the block has to be remachined to use it or ordered that way, or order the block with the 4.840 bore space and the thicker sleeves So i am sticking with 4.500 on the standard maxx block with .300 between the cylinders.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#881931
12/17/10 12:47 PM
12/17/10 12:47 PM
Posts: 901 oh
julian2007
oh
I talked to indy on the phone they gave me some very off the wall numbers that I don't even want to print,all they wanted to do was sell me some parts I was told (last night) 4.530 was the max on the small sleeve block.my question is how much is left at this bore? Thanks,Bruce
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: julian2007]
#881932
12/17/10 01:35 PM
12/17/10 01:35 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
I would never go past 4.505 on the thin sleeve,you will be less than .070.You can have the block bored to accept thicker sleeves.Depending on your application,try and achieve a "happy medium" and not take too much out of the block as cracking can occurr.
#881934
12/17/10 09:13 PM
12/17/10 09:13 PM
B G Racing
Eighty Four, PA
I'm at 4.530 for 5 years now with no issues at all. 588 Ci.
Do you know the thickness of your sleeves and have you done a leakdown test or checked the roundness of your bores?We have a few 588" and 605" but maintain the 4.500 to 4.505 bores even with the thicker sleeves.
[Re: B G Racing]
#881935
12/17/10 09:17 PM
12/17/10 09:17 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
People didnt understand why I went with a 4.44 bore on my Maxx block instead of going straight to a 4.5 bore... For the future over bore's. I would say power diff would go to the stronger, bore with minimal flex also.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
