Street / Strip guys running ET Street Radials.... #881833
12/16/10 04:10 PM
12/16/10 04:10 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
What sort of life can I expect out of a pair? They would make approx. 35 passes a year, and see about 1000 street miles a year. Will they give me at least a few years at that rate?
The reason I ask is that I'm trying to decide whether or not I should just sell off the current Dunlop GT Qualifiers, or keep them for street duty and just use the ET-Radials for strip only. (???)
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881834
12/16/10 04:21 PM
12/16/10 04:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My buddy in his pick up ran them this past drag week,
he put on almost 1200 miles and about 45 passes
and the tire is 3/4 gone... he'll have to get another
set for this coming year but this time we are changing
to a street tire for the road to get them to live
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881835
12/16/10 04:22 PM
12/16/10 04:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
from what i read about 1,500 to 3K miles, I to was in the same boat needing rear tires, i decided why spend $100 for a street tire when for another $50 i could get a drag radial, way better traction, it it will last just as long as a street tire driven hard, my bfg t/a were shot with about 8K. i went with the Nittos they are said to last longer about 12 to 15K but some say they don't hook as hard. i wasn't going for the last tenth.
Re: Street / Strip guys running ET Street Radials.... [Re: ademon] #881836
12/16/10 04:23 PM
12/16/10 04:23 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
2nd
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881837
12/16/10 05:11 PM
12/16/10 05:11 PM
Buy the ET Street bias ply for the street, they last a lot longer and hook better on the street than the ET radials do , at least on my car they do
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881838
12/16/10 05:19 PM
12/16/10 05:19 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What sort of life can I expect out of a pair? They would make approx. 35 passes a year, and see about 1000 street miles a year. Will they give me at least a few years at that rate? (???)
From my experience (and my driving style ), you MIGHT be lucky to get 2 full years of use. I figure more like 1 and change before having to put fresh meats on.
Re: Street / Strip guys running ET Street Radials.... [Re: Cab_Burge] #881839
12/16/10 05:20 PM
12/16/10 05:20 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
yep but they are also even worse in heavy rain if you have a spool.
the real ET Streets are alot more forgiving when "trackprep" is nonexisten or bad also
however the dragradials drives alot better on bad roads
Re: Street / Strip guys running ET Street Radials.... [Re: 1Fast340] #881840
12/16/10 05:50 PM
12/16/10 05:50 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I've tried Nitto's, BFG's and MT ET's on the street. The Nitto's are the best on the street but the worst on the track. BFG's and MT ET's are dangerous on the street if it's wet and neither of them lasted more than about 2000 miles. I'm done with drag radials, now using a decent treaded street tyre and slicks for the track next year.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881841
12/16/10 06:06 PM
12/16/10 06:06 PM
Renton Washington
Triple Threat Offline
Renton Washington
235 OR 255/60/15's I've run them both. I get ~125 passes and roughly 1500-2000 street miles. 50 miles round trip to pacific that I do 20+ times a year. Drive the car to work a few times per week (26 miles round trip), anywhere I want really rain or shine. My car 60 foots about 1.69 at pacific on a normal pass.
Call me lazy, I don't want to swap tires. You shouldn't have an issue getting multiple years from a set.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881842
12/16/10 06:09 PM
12/16/10 06:09 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I've been quite happy with my MT Street Radials. They hook surprisingly well on the street. On my traction challenged truck they hook about 5X as well as "normal" street tires. I've got roughly 1,500 miles on mine and it looks like I may be able to get another 1,000 out of them. I have only driven with them once in the rain and they didn't do anything unexpected - but then I was also being very conservative with them in the rain also.
Re: Street / Strip guys running ET Street Radials.... [Re: Duner] #881843
12/16/10 06:45 PM
12/16/10 06:45 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I got three years out of my last set.
Re: Street / Strip guys running ET Street Radials.... [Re: dustergirl340] #881844
12/16/10 07:33 PM
12/16/10 07:33 PM
IL . usa
cjs69mope Offline
cjs69mope  Offline
IL . usa
i have been happy with the m/h drag radials
hook hard and have had them on for two years now
don't drive in the rain so that i cannot answer
1969 Dodge Charger 1969 Dodge Superbee
Re: Street / Strip guys running ET Street Radials.... [Re: cjs69mope] #881845
11/24/13 04:38 PM
11/24/13 04:38 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
They won't last as long with a spool, it scrubs the tire and the side wall doesn't give like a slick.
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881846
11/24/13 04:46 PM
11/24/13 04:46 PM
Mohnton, Pa
DodgeCharger Offline
Mohnton, Pa
Expect 1 to 2 years. A lot depends on how much of a burnout you do at the track. I do a long burnout. You can see where all the rubber went. In my wheel wells
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881847
11/24/13 05:14 PM
11/24/13 05:14 PM
BradH Offline
BradH  Offline
From my experience, that's about when I'd start looking to see how close they are to needing replacement.
Re: Street / Strip guys running ET Street Radials.... [Re: SpareParts] #881848
11/24/13 05:21 PM
11/24/13 05:21 PM
Fitchburg,Massachusetts
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
#6361132 - Thu Dec 16 2010 02:10 PM
Did they make it a few years?
Re: Street / Strip guys running ET Street Radials.... [Re: MPerry] #881849
11/24/13 06:13 PM
11/24/13 06:13 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
When I could not find the size drag radial I wanted (30 x 9) I got disgusted and just bought radial slicks that are Hoosier's 30 x 9's. I like that size because I wanted atleast a 30" tall tire and I can fit wider in my stock wheelwell but the 9's never rub not even on hard turns. I decided to drive to the track on the radial slicks and then raced on them and drove home. I was surprised how good they handle on the street and since I have a radial tire up front the car handles great with the radial slicks driving normal so I left them on the car and have driven over 2 years on them. I got caught in the rain twice and I had no problems driving real easy and I do have a detroit locker. I have only raced once this year and they hooked great as of course I drove to the track and it hooked good enough to run 10.76 three passes in a row. I dont wory about if it hooks on the street as I dont street race. I plan to go back to a drag radial if they ever make the size I want. Ron
Re: Street / Strip guys running ET Street Radials.... [Re: StealthWedge67] #881850
11/24/13 07:33 PM
11/24/13 07:33 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have about 1500 miles on my ET street radials and maybe 50-60 passes on them and I'm looking to replace them this year.
I'm looking at M&H tires this time around like this one http://www.mandhtires.com/M-H-Racemaster-Cheater-Slicks/28-12.5-15LT#.UpJE-H0o7bU
I've used M&H cheaters before and I liked them
Gus
64 Plymouth Savoy
Dana 60
Re: Street / Strip guys running ET Street Radials.... [Re: MPerry] #881851
11/24/13 07:41 PM
11/24/13 07:41 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Wtf how did I get into this to bump it. Lol sorry guys
Re: Street / Strip guys running ET Street Radials.... [Re: SpareParts] #881852
11/24/13 07:50 PM
11/24/13 07:50 PM
MPerry Offline
Mopahts memba'
MPerry  Offline
Mopahts memba'
Its not a big deal but now curious minds want to know how long they lasted.
Those M&H tires used to be made in Gardner,Mass.
