440 Aluminum Intake Torque #880722
12/15/10 12:24 PM
12/15/10 12:24 PM
Out in Left Field, NY
bobs66440 Offline OP
I have a Offenhauser dual quad and I can't find any torque specs on it. I see that a cast iron intake is 40lb/ft but Edelbrock recommends their aluminum intakes at 25lb/ft. Any help would be appreciated.
Re: 440 Aluminum Intake Torque [Re: bobs66440] #880723
12/15/10 12:31 PM
12/15/10 12:31 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Never worried about toque specs on an intake. started in the center and criss crossed outward alternating ends and sides and tightening in small amounts each time around till tight. Never had a problem.
Re: 440 Aluminum Intake Torque [Re: MoparforLife] #880724
12/15/10 12:32 PM
12/15/10 12:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Just don't exceed 30 ft/lbs !!
Re: 440 Aluminum Intake Torque [Re: bobs66440] #880725
12/15/10 04:28 PM
12/15/10 04:28 PM
I'd find the factory circular pattern in a motors manual or other book & adhere to it & the flange thickness should be pretty close between eddy/offy so as said 25 on cleaned/lightly oiled bolts and chased holes w a thread cleaning tap rather than a regular tap. & at least 3 or 4 trips around to get up on it slowly. A bit picky but that's me.
Re: 440 Aluminum Intake Torque [Re: MoparforLife] #880726
12/15/10 04:53 PM
12/15/10 04:53 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
The "proper torque Police" are going to you !!
