reverse broke on my 4 speed. Help
#88058
07/13/08 05:45 PM
07/13/08 05:45 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
So the other day I wanted to back the charger in the garage and reverse was very hard to shift into for some reason. I tried a few times to get it into reverse and then I tried a little harder then snap. The tab that the linkage hooks up to snapped on the shifter. Any ideas as to why this would happen?
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: reverse broke on my 4 speed. Help
[Re: 69charger440_6pa]
#88059
07/13/08 10:45 PM
07/13/08 10:45 PM
Posts: 3,449 Gateway to the West.
hemi_harvester
Got any Lube in the trans ?
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
[Re: hemi_harvester]
#88060
07/13/08 10:58 PM
07/13/08 10:58 PM
69charger440_6pa
Oakley CA
well I filled it when I put the motor in about 3 years ago and it never leaked a drop so I would def. think so.
