What is the limit of a mechanical fuel pump? #880276
12/14/10 10:15 PM
12/14/10 10:15 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Is there an E.T. cut off where say anything faster than a given time would signal that you should install an electric pusher type fuel pump in place of a traditional mechanical pump?
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880277
12/14/10 11:25 PM
12/14/10 11:25 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
most roundy round cars are required to run a mechanical fuel pump...so there are some heafty pumps that support alot of hp...
they are rebuildable and tuneable.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880278
12/14/10 11:26 PM
12/14/10 11:26 PM
My old M.W. stocker went 11:20s ET at 3550 Lbs. at 119.+MPH with a mechanical pump only and a piece of crap stuck in the fuel tank pickup that I didn't know about until after I sold it. There was other M.W. stockers at the same race that went 124 MPH using the mechanical pump with a Holley blue as a pusher pump in the back My car ran faster with the mechanical pump only versus using the Holley as a pusher hook up to the mechanical The pumps we used back then where the Hemi Carter NASCAR race pumps, they have three diaphrams in them instead of the standard two diaphrams
Re: What is the limit of a mechanical fuel pump? [Re: Cab_Burge] #880279
12/15/10 12:09 AM
12/15/10 12:09 AM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I guess I will be ok with my Carter street/strip mech pump and 3/8 line up to 11.5 then.....right?
'72 440 Cuda
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880280
12/15/10 03:21 AM
12/15/10 03:21 AM
Phoenix
jinxy Offline
jinxy  Offline
Phoenix
I've gone 11.33 @ 118.6 in a 3400# race wt Dart with a Carter strip pump with 5/16" line. It is suprising, but I run an Innovate o2 gauge and it reads between 12.8 and 13.0 a/f ratio through the traps.
Re: What is the limit of a mechanical fuel pump? [Re: jinxy] #880281
12/15/10 12:50 PM
12/15/10 12:50 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
10.5 @ 126 MPH here with a Clay Smith MP. I've seen a friend's dragster go 8.4's in the 1/4 on alcohol with one of these pumps. I'm real confident that low 10's/high 9's would be no problem. Jim
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880282
12/15/10 01:00 PM
12/15/10 01:00 PM
an8sec70cuda Offline
Back when my car ran 11.40s at 117 mph, I was running a Carter strip pump mechanical pump and the factory 3/8" line. I "upgraded" to -8 line, put a sump in the tank, and got a Holley blue pump. Did not change the performance at all.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What is the limit of a mechanical fuel pump? [Re: an8sec70cuda] #880283
12/15/10 01:54 PM
12/15/10 01:54 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I dont have any real input, but some have said they work
www.racepumps.com
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880284
12/15/10 02:21 PM
12/15/10 02:21 PM
organ
maximum entropy Offline
organ
put a fuel pressure gauge in it, and then you'll know. i have a carter strip mechanical pump, 3/8 line, in a high ten second street car. the pressure is 6.5 at launch, and 6.5 at the stripe. i get the feeling i'm not even close to needing more.
Re: What is the limit of a mechanical fuel pump? [Re: maximum entropy] #880285
12/15/10 02:54 PM
12/15/10 02:54 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
A customer I just build an engine for Has a 500" lowdeck, car weighs 3800lbs and the other week I went 6.80 @ 102 in it, and it has a stock fuel pump he would not change it even with me on him about it. Didn't miss or anything, actually kind of surprised me by far the fastest I have seen a stock pump go.
One day I will have something cool here.
Re: What is the limit of a mechanical fuel pump? [Re: sdaurity] #880286
12/15/10 03:43 PM
12/15/10 03:43 PM
UK
602heavy Offline
602heavy  Offline
UK
Had a stock carter mech pump on the 605" , was all done around 4000rpm motorway driving.
Re: What is the limit of a mechanical fuel pump? [Re: 602heavy] #880287
12/15/10 04:09 PM
12/15/10 04:09 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I ran 11.20's in a 69 Coronet with a $25 Napa fuel pump and stock 5/16 fuel line. I switched to a 1/2 hard aluminum line and a Holley blue and saw zero gains.
Re: What is the limit of a mechanical fuel pump? [Re: Bob_Coomer] #880288
12/15/10 05:20 PM
12/15/10 05:20 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If you change your fuel line to 1/2" the stock & Hi-Perf mechanical pumps can't keep the fuel pressure up for very long without adding a pusher pump; the Carter or the Holley Blue are plenty adequate for that. For 5/16 or 3/8 fuel line, a good mechanical pump alone should be plenty.
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880289
12/15/10 05:22 PM
12/15/10 05:22 PM
AndyF Online content
AndyF  Online Content
NASCAR runs more than 800 hp with mechanical pumps.
Re: What is the limit of a mechanical fuel pump? [Re: AndyF] #880290
12/15/10 07:31 PM
12/15/10 07:31 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
For that matter top fuel and funny car run mechanical pumps
Yes I live in Michigan, so there is still 1 light on
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880291
12/15/10 07:34 PM
12/15/10 07:34 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i have a mech fuel pump i bought,its capable of any sb power,its made by racepumps,i never used it because its really not the best for street driven beast,,heat from the headers at stop lights can be a pain.ps i still have it in the box.
Re: What is the limit of a mechanical fuel pump? [Re: 440dart] #880292
12/15/10 11:07 PM
12/15/10 11:07 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
For that matter the Space shuttles three main engines are capable of producing 37 Million HP with a mechanical pump.
The pump alone produces 71,000 HP Is this the Limit I bet not!
Tywebb, Even though the Carter 120 GPH race pump "should" be more then enough for your combo. Its not as easy as that, Technically a 50 GPH pump should work.
But , without any ramblings the Carter 120 GPH race pump that I used failed to deliver enough with my fuel line ETC on my 509 750 carb combo. It should of been more then enough for me too.
I got a bad pump I guess. You could be having a fuel issue. But I recommend putting a guage on it to be sure.
Im not sure I wouldnt rule out a Vert problem with your ATI. It lost 2 MPH over your 10" turbo action, with the same said pump and similer ET , I believe from your prior thread.
Didnt you post the slippage difference too, I forget.
I do love the 9.5" Dynamic, but I would think that 8" ATI you have would kick its but, if it wasnt slipping so much. mike
Re: What is the limit of a mechanical fuel pump? [Re: Sport440] #880293
12/15/10 11:16 PM
12/15/10 11:16 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Thanks for all of the feedback everyone. Based on most are saying I should be fine but I guess it would be nice to have a gauge viewable from the cockpit to see what the pressure is at the stripe. I would need an electric gauge with a sending unit if I want to put it in the car.....right?
Sport440....I talked to ATI this week and they said my 8" vert is the tightest they make. I am going to put it in the car and make a few more passes with it in 2011 and see what happens.
'72 440 Cuda
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880294
12/15/10 11:51 PM
12/15/10 11:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A mech fuel pump is pretty simple... diaphragm, inlet,
outlet check valves and the pressure spring, then
the actuator arm... the diameter and stroke of the
diaphragm determine the volume... but the inlet and
outlet check valves are the restriction in the pump.
Some companies run 2 inlets and 2 outlet checks to
move more fuel with the big diaphragms... the pressure
spring on the back of the diaphragm will determine
the pressure based on the restriction of the needle
and seat.... I flowed a few thousand warranty pumps
for Chrysler in the fuel lab and tore many apart to
determine what the failures were
Re: What is the limit of a mechanical fuel pump? [Re: tywebb2] #880295
12/16/10 03:32 PM
12/16/10 03:32 PM
I found out the hard way that some electric tachs are not accurate, even high dollar race tachs Some of todays and some of the old race ignitions mess eletric tachs up above a certian RPM which may make your finish line RPM reading off so it looks like the converter is no good
