push rod blues
#88008
07/13/08 05:14 PM
07/13/08 05:14 PM
Posts: 32,922 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
These are the intake push rods from my 408 Stroker. Resultes of a bad TQ leaking all the gas into the cylinder and creating a hydrolock. The truck ran 15.0s with these. What do you think it will run with new rockers and push rods? 4300lbs with driver, 2.94 rear 28" tires
Re: push rod blues
[Re: stumpy]
#88009
07/13/08 05:45 PM
07/13/08 05:45 PM
moparpollack
Lil Herman
Lil Herman
85086
Post the pics
Re: push rod blues
[Re: moparpollack]
#88010
07/13/08 11:39 PM
07/13/08 11:39 PM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
Probally wont run with all those bent rods that came out.You probally have bent valves at the least.If you had that much gas in the cylinders you probally washed out the rings also.Better pull the heads and check that and for possibly bent rods.Rocky
Chrysler Firepower
Re: push rod blues
[Re: therocks]
#88013
07/14/08 10:23 AM
07/14/08 10:23 AM
stumpy
Grand Prairie,Texas
Well it's been running like that for about 2 months best I can figure. It was turning 15.0s during that time. It ran well enough that I didn't know the rods were bent. Cruised 70mph at 2500rpm sweet as can be. No bad noises,no miss,no indication at all. I was pulling the intake to cure a vacuum leak when I found them. Just kidding about what it will run. I wondered how much power was lost with the intakes barely opening.
Re: push rod blues
[Re: stumpy]
#88014
07/14/08 10:59 AM
07/14/08 10:59 AM
huh! I need new pushrods too. Im putting together my stroker and found one of the original ball/cup rods bent and a bunch of others looked like the were starting to bend.
Mancini racing has p/n MRE7115 5/16" chrome moly PR for $75. good to over 300lb spring pressure
