Page 1 of 3 1 2 3
Going to alky.....how much difference? #879754
12/14/10 12:11 PM
12/14/10 12:11 PM
Out West
408strokerdart Offline OP
Out West
Just playing with the thought of going to alky injection. I would probably go with a Rons T2 system. Just wondering how much 1/8th mile et you picked up on your previous gas combo by making the change?
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879755
12/14/10 12:44 PM
12/14/10 12:44 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
From what I've seen, alcohol can pick you up between 2 and 4 tenths. It seems to pick up lower compression motors up more than higher. So if your at 11:1 and go alcohol, I would expect 4 tenths, if your at 13:1, I would expect 2 tenths. (in 1/4 mile)
Injection is worth some on it's own, so I would look for somewhere around 2 tenths in the 1/4 with injection.
Everyone see different results, this is just what I've seen over the years and with my experience.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Going to alky.....how much difference? [Re: WadeMetzinger] #879756
12/14/10 01:07 PM
12/14/10 01:07 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
I've changed to methanol(pro systems SV-1) picked up close to 2 tenths 12.5:1 CR.The only draw backs are hard starting in cold weather and a little more fuel system maintenance.I can purchase methanol locally for about $150.00/drum.So far I really like it.
Re: Going to alky.....how much difference? [Re: DavidDean] #879757
12/14/10 01:42 PM
12/14/10 01:42 PM
Out West
Out West
.2 in the 1/8th mile or 1/4?
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879758
12/14/10 02:23 PM
12/14/10 02:23 PM
NC
440Jim Offline
440Jim  Offline
NC
I only have limited experience, so FWIW my opinion.
Typically in hot weather you can see 0.3 tenths in the 1/4 mile, so maybe .2 in the 1/8th mile. The torque improvement can show more improvement in the 1st half of the track.
In cold weather, the ET difference will be less. And in mineshaft air it might be too close to call. But people have reported different results in different combos.
I also am a firm believer that alcohol can make a car more consistant from less change with weather changes. But some gas combos are very consistant too.
If you go alcohol injection, give serious thought to a gas primer/idle system. This helps put/keep heat in the motor, easier cool weather starting, saves fuel, etc. Recommended, but not required !
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879759
12/14/10 02:41 PM
12/14/10 02:41 PM
gregsdart Offline
gregsdart  Offline
An injector will show more gain due to less restriction over an Alky carb.
Re: Going to alky.....how much difference? [Re: gregsdart] #879760
12/14/10 03:59 PM
12/14/10 03:59 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
No ABA testing so it is hard to say. General concensus is .1-.3 from gas carb to alky injection. I am a certified alkyholic and have run both carb and injection. If starting from scratch go injected if already carbed call George Rupert and bolt one of his on. Not all motors like alky but I have only had one to date that was faster on gas, single dominator of course.
Re: Going to alky.....how much difference? [Re: MegaDart] #879761
12/14/10 04:19 PM
12/14/10 04:19 PM
Out West
Out West
I am going to be closer to where I need to be with cam/intake changes and some weight reduction, but I am still lacking a small amount of improvement to go 5.80 in the summer heat. Going to run this index this coming year and just don't want to come up .05 short in the heat so looking for a realistic .10 improvement and also need to know what to do with all of this compression if I make the switch. Do I need a front mounted tank and engine driven pump with bypass? Can I use my current trunk mounted tank for alky since it is non anodized bare aluminum? I just hate to jump into something expecting $3k in cost just to have it cost me $5k.
Re: Going to alky.....how much difference? [Re: MegaDart] #879762
12/14/10 04:26 PM
12/14/10 04:26 PM
W. Kentucky
justinp61 Online content
justinp61  Online Content
W. Kentucky
A friend of mine runs a pretty mild 499 in a Omni/Charger. He switched from carbureted gas to carbureted alcohol, IIRC he picked up about a .15 in the 1/8 with it. The 60' picked up quiet a bit.
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879763
12/14/10 04:28 PM
12/14/10 04:28 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
The difference between Q16 and methanol is negligible. If you want to stay with gasoline swith to Q16.
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879764
12/14/10 05:12 PM
12/14/10 05:12 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
? What do you mean?
Re: Going to alky.....how much difference? [Re: 440Jim] #879765
12/14/10 05:21 PM
12/14/10 05:21 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
and A+ for the primer plus gas system. It sure makes my life better. I'm with Ryan J. What do you mean? Alky loves compression.
Diego
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879766
12/14/10 06:16 PM
12/14/10 06:16 PM
Kentucky
sc301v Offline
sc301v  Offline
Kentucky
It really all depends on how good and effecient your gas system is now....Some will see big gains and some will see none....rather it be carb or injection...I have ran alky for 18 years and used pretty much every style of induction possible...My favorite still to date is tunnel ram and 2 carbs.
Re: Going to alky.....how much difference? [Re: Diego_Ted] #879767
12/14/10 06:32 PM
12/14/10 06:32 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have also run both carb and a birdcatcher injection system and didn't see that much gain. around .12 or so
Re: Going to alky.....how much difference? [Re: RyanJ] #879768
12/14/10 06:35 PM
12/14/10 06:35 PM
Out West
Out West
? What do you mean?
Just thought I was on the high side for going alky?
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879769
12/14/10 06:47 PM
12/14/10 06:47 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I have always heard alcohol runs better with a higher CR. You can also run VP M5 if regular alcohol is not enought. We just bumped the CR ratio up from 14.2-1 to 15.2-1 because I changed over to alcohol.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879770
12/14/10 06:48 PM
12/14/10 06:48 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
? What do you mean?
You can always get by with more compression on alky vs gas.
15:1-16:1 no problem for alky.
This one was 15.8:1
Re: Going to alky.....how much difference? [Re: Bob_Coomer] #879771
12/14/10 07:18 PM
12/14/10 07:18 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
My fuel system consists of a rear mounted fuel cell w/ 2#8s feeding Aeromotive A2000 mounted near the cell w/by pass to tank line pressure is set at 25#.Out of the pump is a #10 which feeds a Pro System special regulator set according to thier instructions. This system flows a gallon in about 11 seconds. My data logger says the system pressure is 11-12# during the run. I've tried VP M-3 and it ran the same for me as regular methonal. I bought a drum of M-5 to try but never made a pass just tried to get the tune up right it,sure is a lot more stinky (nitro parrafin)than regular methonal. I looked at Q16 but It looked pretty pricey.I also like the methanol because your opponent cant hurry you or burn you down. By the way I've got an APD alky dominator if anyones intrested.
Re: Going to alky.....how much difference? [Re: DavidDean] #879772
12/14/10 07:57 PM
12/14/10 07:57 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If you go with a Ron's the throttle response is unreal.Also I can do a hard burn-out(dragster)jam on the brakes back it up & stage,never have to clean it out. Your days of over heating issues will be a thing of the past. At the 1st of the season I brought 3 drums 162 gallons of 99.9% alcohol for $314.76 with tax.
That's a little more info. to help you deceide
PS have not run mine a lot,but every oil change the oil has been clear.
Re: Going to alky.....how much difference? [Re: 408strokerdart] #879773
12/14/10 08:36 PM
12/14/10 08:36 PM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
? What do you mean?
It's a high static #, but with wide LSA & alot of duration, I'm sure the cranking pressure & dynamic is'nt that radical.
Methanol is unusual stuff from my limited research on it, it has a really high RON # like in the low 130's, but a low MON # in low 100's. I just know alot of turbo cars especially 4 cyl stuff with really high boost (30+) are going to it. & if it lives in those apps, it will be more than fine in yours.
I'd start out on cheap M1 VP & then try their new M5 stuff... I talked to one guy @ track last fall who was running the M5 in his BB GM Dragster & was real happy with it. I've never tried it, but if I was running meth I certainly would. I'm injecting M1 into my turbo motor, M5 is not recommended for pre-compressor due to it's increased volitility...
Page 1 of 3 1 2 3
