Re: SS LEAFS VS CAL-TRAC MONOS [Re: W5Duster436] #878419
12/13/10 03:18 PM
12/13/10 03:18 PM
Az
Crizila Offline
Crizila  Offline
Az
Leafs are the same width - 2.5". Going with single leaf springs, your issues are going to be with pinion angle.
I just got it all put together but haven't checked the pinion angle yet. How much did you notice yours being off after going to the monoleafs?
Well, let me clearify that I am putting single leaf CatTracs on a late B with an ISO system and 3800 lb HD ( 22" front section ) 5 leaf springs. That system had a 3.5* diff angle. My intention was to use the stock ISO perches and just beef them and modify the locator hole to accept the 1/2" centering pin on the single leaf springs ( also 22" front section). When I bolted it back up, my diff angle was now at 11*! Way too much to shim or do anything with. Torched everything off and I am going to start over with new perches from Calvert. They make the best I've seen BTW. You may not have the same issues, but make sure you measure if you are using your existing spring perches over as I just about guarantee there will be some change.
Fastest 300
Re: SS LEAFS VS CAL-TRAC MONOS [Re: Crizila] #878420
12/13/10 03:47 PM
12/13/10 03:47 PM
Indiana
W5Duster436 Offline
W5Duster436  Offline
Indiana
I may be lucky however because just realized that I purchased my diff from a member here who was running caltracs and monoleafs as well. My guess is he had already checked pinion angle when he moved the perches in 3/4".
Fingers crossed at least..
'70 Duster - SDSS 436 W5 4spd (Gone)
'71 Dodge D100
'70 Dodge W100
Re: SS LEAFS VS CAL-TRAC MONOS [Re: W5Duster436] #878421
12/13/10 09:06 PM
12/13/10 09:06 PM
Az
Crizila Offline
Crizila  Offline
Az
Stock perch location and single leaf springs on a late B body. Not a good thing - 11* diff to driveshaft angle.
Fastest 300
Re: SS LEAFS VS CAL-TRAC MONOS [Re: Crizila] #878422
12/13/10 09:08 PM
12/13/10 09:08 PM
Az
Crizila Offline
Crizila  Offline
Az
These are the perches Calvert sells - hopefully welded at the right angle.
Fastest 300
Re: SS LEAFS VS CAL-TRAC MONOS [Re: MIKES_DUSTER] #878423
12/13/10 10:20 PM
12/13/10 10:20 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Guys.....Stop busting my chops!!!! Ive been talking with Kyle for about a month now about wheel sizes and back spacing. He has Mono-leafs and I have SS leafs. We were comparing measurements and I was just wondering if the leafs were the same size or different...THATS IT!!!!
It will be some time before I will be able to go to the track becasue of money and now me having stage 3 cancer and starting chemo tomorrow. My duster is the LAST thing on my mind now!!!!
Mike, you have a PM
Re: SS LEAFS VS CAL-TRAC MONOS [Re: actionange] #878424
12/14/10 07:27 PM
12/14/10 07:27 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline OP
Tony and James.....Im sorry for the lash back. Was just going thru thinking of starting chemo and the effects and then you guys WHACKED me!!!! LOL....I can usually take it like a big boy and if so,take some more but the other day I was just NOT in the mood....Sorry again!!!
Thanks to all of you for your thoughts a prayers. My cancer started as testicular cancer,they removed it but was too late and it has spread to my lymphnodes and possible a lung. My PT/Scan report came in yesterday and I have a lymphnode that is 1.9cm big. I am taking 5 days of chemo then 2 weeks off. I will do this for 4 weeks for a total of 20 days of chemo.
THANKS everyone!!!!
Re: SS LEAFS VS CAL-TRAC MONOS [Re: MIKES_DUSTER] #878425
12/14/10 07:30 PM
12/14/10 07:30 PM
Orlando Florida
blown572dart Offline
Orlando Florida
no issues Mike sorry your going through it.
Again keep your chin up
Re: SS LEAFS VS CAL-TRAC MONOS [Re: blown572dart] #878426
12/14/10 09:49 PM
12/14/10 09:49 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i don't know you mike but sorry to hear about the cancer, you can beat it, all the best. kick it's a$$ then go race that duster.
Re: SS LEAFS VS CAL-TRAC MONOS [Re: dirtybee] #878427
12/14/10 10:32 PM
12/14/10 10:32 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Keep the faith, may god bless you
My prayers go out to you and your
family, Speedy Recovery
