Adjustable axle bearings with cone type posi #878253
12/12/10 05:21 PM
12/12/10 05:21 PM
Grand Forks, ND
Hemi_Ram Offline OP
Hemi_Ram  Offline OP
Grand Forks, ND
I know when you are using the stock type axles with end play adjustment there are pins on the sure grip unit to aid in the end play adjustment. Can I use the stock setup with an auburn posi unit? What acts to help transfer the end play to each axle like the pins in the sure grip(clutch) unit? Thanks
Re: Adjustable axle bearings with cone type posi [Re: Hemi_Ram] #878254
12/12/10 05:27 PM
12/12/10 05:27 PM
scratchnfotraction Offline
they have a sliding thrust block on the pin for the spider gears
or it has the buttons/roll pin
I remove that when running green bearings,non adjustable
