super stock leaf springs??????
#878166
12/12/10 01:38 PM
12/12/10 01:38 PM
Posts: 12 usa
honcho
usa
Hey folks,thinking of adding super stock leaf springs to my ride. How difficult is the modification? I think you have to add an extra hanger,dom they bolt on or weld on? Thanks for any info
66 coronet 500 convertible 440 mag/727/2500 stall/323 rear/430hp
Re: super stock leaf springs??????
[Re: screamindriver]
#878168
12/12/10 02:56 PM
12/12/10 02:56 PM
Posts: 12 usa
honcho
usa
well I don't want the car to look uneven. I just want to give it a slight raise in the back for a bigger tire
[Re: honcho]
#878169
12/12/10 03:14 PM
12/12/10 03:14 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I would contact Mancini racing for HD springs I believe they use a local spring shop in Detroit to make their springs. They also have package deals with bolts or shackles sometimes ![](/ubbthreads/images/graemlins/Twocents.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#878170
12/12/10 03:19 PM
12/12/10 03:19 PM
Posts: 12 usa
honcho
usa
Yea,I checked Mancini but found another place 100$ cheaper http://www.mopartsracing.com/ so if the SS springs are a bolt-on app I will get them from here. Just didn't want to do any welding ![](/ubbthreads/images/graemlins/smile.gif)
[Re: honcho]
#878171
12/12/10 04:13 PM
12/12/10 04:13 PM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
No welding.But unless you have an A body you need the different front hangers.Rocky
Chrysler Firepower
[Re: therocks]
#878172
12/12/10 05:38 PM
12/12/10 05:38 PM
Posts: 92 south carolina U.S.
DOUGG
south carolina U.S.
I added ss springs to my 65 ordered two right side springs and that gave the lift I wanted & she still goes straight on launch. Works for me.
[Re: DOUGG]
#878174
12/12/10 06:45 PM
12/12/10 06:45 PM
Posts: 12 usa
honcho
usa
why did you order 2 right sides?
[Re: AndyF]
#878176
12/12/10 07:07 PM
12/12/10 07:07 PM
Posts: 12 usa
honcho
usa
so I should order 2 right sides and the car will look level and drive correctly?
[Re: therocks]
#878178
12/12/10 07:21 PM
12/12/10 07:21 PM
Posts: 1,565 tennessee
pushbutton
tennessee
I installed a set on my 63 Savoy and they fit with the stock hangers. Wish i'd used two lefts though as it does set higher on the right. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: pushbutton]
#878179
12/12/10 09:00 PM
12/12/10 09:00 PM
Posts: 12 usa
honcho
usa
ok,so do 2 right sides,because of the arch?This is so damn confusing
[Re: honcho]
#878180
12/12/10 09:11 PM
12/12/10 09:11 PM
DOUGG
south carolina U.S.
Honcho, I believe the difference between left & right springs is the number of leafs . I used 2 rights on my street car to get an even stance and still have good(great) spring reaction on launch. Plus I was afraid that different spring rates(l-r) might affect handeling in curves.
[Re: DOUGG]
#878181
12/12/10 09:36 PM
12/12/10 09:36 PM
Posts: 12 usa
honcho
usa
Hey DOUGG ,what ride do you have? I just wanna make sure when I order these springs,I am gonna do it right. If the passenger side is stiffer,than i will go with that
[Re: honcho]
#878182
12/12/10 10:09 PM
12/12/10 10:09 PM
DOUGG
south carolina U.S.
It's a 65 satellite,3450 lbs. I used 2 R-side 3400 lb. springs.gave me the height I wanted in back,car hooks up well, & nothing scary on curvy mtn. roads. I hope you understand that these s.s. springs give a stiffer ride than stock. Not uncomfortable, but stiffer(much better than air shocks)
[Re: pushbutton]
#878183
12/12/10 10:12 PM
12/12/10 10:12 PM
Posts: 31,076 Oregon
AndyF
62-63 B body cars can use stock hangers. All the other B body cars need longer hangers. The hangers are different for Ply and Dodge cars and they vary by the model year. Mancini Racing has all of the correct hangers, you just need to tell them which car you have and what year it is.
