360 Stroker Kit, which one to use?
#876988
12/10/10 06:41 PM
12/10/10 06:41 PM
Posts: 473 Fort Lauderdale, FL
Suregrip
Fort Lauderdale, FL
Looking to rebuild a 360 in a LRE for street use, with occasional towing. Would like to have 400 cubes or more with around 400-500 foot pounds torque in the mid-range. Should I go internal or external balance and why? I intend to use stock manifolds and a mild cam, with a dual-plane intake, T-Quad 850, 2500 stall 727A, 3:23 sure-grip. Looking for stroker kit recommendations, and cam recommendations...
Re: 360 Stroker Kit, which one to use?
[Re: Suregrip]
#876989
12/11/10 12:35 AM
12/11/10 12:35 AM
RapidRobert
Eagle cast 4" crank <$300 & KB stroker hypereutectics would be a reasonable start.
[Re: RapidRobert]
#876990
12/11/10 03:21 AM
12/11/10 03:21 AM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Eagle cast crank would be a terrible start. Get at a minimum a SCAT cast crank, SCAT I beam rods and KB pistons if you are going to use the original open chamber heads or wiseco if you are gonna get a decent head (closed chamber).
The problem with the Eagle crank is the overlap area between the main and rod journals, they grind away all the meat there in an attempt to make them balance internally, long story short, it don't work, they still need mallory to internally balance and the crank is severly weakened, I have seen them break in an almost stock magnum motor, low compression, stock cam, stock intake, stock ex manifolds... took about two weeks.
I would talk to Dan at performance only in florida for a good deal.
[Re: Suregrip]
#876991
12/11/10 03:26 AM
12/11/10 03:26 AM
HotRodDave
Kalispell Mt.
External balance is fine in your case, if you chose to go internal balance you should then step up to a steel crank as the extra cost of the mallory required to internally balance a cast crank will offset the cost of the entry leval steel crank like a SCAT or K1. Eagle makes so much junk I will not even buy what little bit of good stuff they make on princaple.
[Re: goldmember]
#876994
12/11/10 09:31 AM
12/11/10 09:31 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Are you suggesting the EAGLE cast crank is garbage? I'll agree! They look like a 4yr old used an angle grinder to work them. Absolutely no way I'd think of using one.
A month or two ago I looked at a 408 with a cast Eagle crank, with 160 miles on the motor.
The crank was cracked at the number 8 journal, Eagle told the Dakota owner his automatic tranmission shifts too hard and broke the crank!
Needless to say... Eagle cranks are sh*t in my book.
[Re: Dartcuda]
#876998
12/11/10 03:11 PM
12/11/10 03:11 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
Call Nick at www.compu-flow.com and he will set you up with great parts that work and even better advice Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#876999
12/11/10 05:37 PM
12/11/10 05:37 PM
Suregrip
Fort Lauderdale, FL
So if I use a Scat cast-crank hit for 408 cubes, it would still be externally balanced and I could use the original balancer? Should I up-grade the balancer and flex-plate? Will a 360 balancer be enough weight for a 408 or should I use something else? I would still use a weighted torque converter for a cast crank 360? Which after-market balancer would keep the stock pulley alignement? Thanks...
Some people you just can't reach...
[Re: Suregrip]
#877000
12/11/10 05:47 PM
12/11/10 05:47 PM
HotRodDave
Kalispell Mt.
If you use an external balanced kit then you can use your original balancer and converter.
[Re: HotRodDave]
#877001
12/11/10 05:51 PM
12/11/10 05:51 PM
Suregrip
Fort Lauderdale, FL
Okay, that's what I was thinking, is there a better balancer I should use or will my old one be okay weight wise? Is it worth me upgrading to a better flew plate or just use the old one as well? What are you thoughts for a cam? Thanks again!
[Re: RobX4406]
#877003
12/11/10 06:56 PM
12/11/10 06:56 PM
Suregrip
Fort Lauderdale, FL
Not 100% sure but Summit seems to show a kit which is cast crank internal balance or same kit cast crank with zero balance. Check them out at Sumit 1-98113 and 98113BI these are both with 20cc dished pistons... Remember this is for a street truck not a bracket racer looking for torque more than HP.
[Re: RobX4406]
#877005
12/11/10 07:32 PM
12/11/10 07:32 PM
Suregrip
Fort Lauderdale, FL
So I could use my stock 360 balancer with the 1-98113 kit? But the other kit 1-98113BI would need a neutral balancer? I am getting this right?
[Re: Suregrip]
#877006
12/11/10 10:15 PM
12/11/10 10:15 PM
HotRodDave
Kalispell Mt.
As long as your balancer is not in bad shape the stock one is fine for mild street/strip use. Check for dry rot in the rubber or if the outer shell has turned in relatio to the outer shell. If it checks out OK I would use it. Cam is gonna depend on the heads but in general a cam around 230@.050 duration with about .480 lobe lift would be good. I would recomend the comp XE268 with open chamber heads or the comp 280 magnum with a good head like a magnum that flows good in relatio to the intake. If you are gonna get a good aftermarket head like an RHS X head or eddelbrock then you might look for a higher ratio rocker to take advantage of the aditional airflow potential.
