Is anyone using Stahl SB A-Body headers? #876924
12/10/10 06:12 PM
12/10/10 06:12 PM
Glendale Az
Darryls-Demon Offline OP
Glendale Az
If so how well do they fit? Also do you have any Pics of them in the car and how close do they come to the oil pan?
Thinking about a set for my Street car with W2 heads.
Re: Is anyone using Stahl SB A-Body headers? [Re: Darryls-Demon] #876925
12/11/10 12:50 AM
12/11/10 12:50 AM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
I had an old pair of big block 2" fenderwells and the fit and quality were good, but when it was time to replace them, the cost was 2X Hookers or Proparts. I got the Proparts and there was no difference in performance.
Re: Is anyone using Stahl SB A-Body headers? [Re: Darryls-Demon] #876926
12/11/10 01:07 AM
12/11/10 01:07 AM
Canada
Max Weg Offline
Max Weg  Offline
Canada
I have a set on my Stock Eliminator each side has one tube that exits through the fenderwell and wraps around the frame. The fit fairly well and are not to close to the oil pan. I will check photos and see if I have one with the oil pan in view.
Max Weg
Re: Is anyone using Stahl SB A-Body headers? [Re: cgall] #876927
12/11/10 01:08 AM
12/11/10 01:08 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Been a set on my '70 Duster since it was new; it's always been a drag car. Slip-fit primaries, one on each side goes through the apron, collectors bolt on using tabs. Clears a huge oil pan & the trans, tight at idler arm. Tight at brake lines. Requires adapters at the cylinder head if your heads have the OEM bolt pattern. Flanges are real tight if you use 13/16" spark plugs, but 5/8" are a breeze. No interference with my 7.10x15 Moroso ft tires. No ground clearance issues unless your trailer lacks a beaver-tail.
Here's a left-side photo, with Batten W2 heads. Being an old SS/IA car, the engine location's been juggled a bit.
Re: Is anyone using Stahl SB A-Body headers? [Re: topside] #876928
12/11/10 08:00 AM
12/11/10 08:00 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Does anybody have a set of $tahl 1 3/4" x 3" for A-body/SB? (stock heads)
I have a set of Hooker 5303 (1 7/8") and think 1 3/4" might be a little
quicker for my 340.
Re: Is anyone using Stahl SB A-Body headers? [Re: S/ST 3040] #876929
12/11/10 11:56 AM
12/11/10 11:56 AM
Glendale Az
Glendale Az
I think The $tahl 1 3/4 x 3 would be the best size for my mild 408, seems to me the 1 5/8 TTi step headers would be to small and the 1 7/8 too big.
Any one have a nice set they want to sell?
Re: Is anyone using Stahl SB A-Body headers? [Re: Darryls-Demon] #876930
12/11/10 03:13 PM
12/11/10 03:13 PM
Edmonton alberta Canada
mr. 63plymouth Offline
Here are the only pic I have, in a 68 barracuda! With these headers the car went 9.52@ 143! In street clothes!! Love them. And they might be for sale!! ! 1/3/4" x 3"
Re: Is anyone using Stahl SB A-Body headers? [Re: mr. 63plymouth] #876931
12/13/10 01:50 PM
12/13/10 01:50 PM
Glendale Az
Glendale Az
Any one else using these headers?
Re: Is anyone using Stahl SB A-Body headers? [Re: mr. 63plymouth] #876932
02/26/11 04:13 PM
02/26/11 04:13 PM
S/ST 3040 Offline
S/ST 3040  Offline
Do you still have the Stahl 1 3/4" x 3" headers?
