408 stroker cam options (street use) #87691
07/12/08 07:37 PM
07/12/08 07:37 PM
Alton, IL
Dakota_Don Offline OP
Alton, IL
HI , I HAVE A CAM QUESTION.
I am building a 410 (360) stroker
It has 587 cast iron heads, ported with 2.02 and 1.60 valves bowl work ect...
it flows aprox 250ish at 500 lift for the int, amd 168ish on the ex.
1.5 ALU rockers
It will be 10.02:1 CR with forged pistons, scat crank and rods int ballanced, I have an rpm airgap, with a holley 770 avenger carb,
it also has hooker super comp 1 5/8 long tube headers. it also hasa 904 auto with a 2800 stall and extra clutches and low 1st gear set installed w/ shift kit. the Dakota also has 3:55 gears going to 3:73 8.8 phord rear 5 on 4.5 lugs soon.
it also has FBO ignition system w/out Vac advance.
what cam would be a good choice for my street drivin 96 dakota I do have the comp XE274H cam 230/236 @488/491 lift from my current old combo w/only a brake in run. would this camshaft be good or should I use a different one. I am told this cam should be ok and would idle like a stock engine. what are your thoughts. and plz tell me about the .906 cams?
thanks
Don
Re: 408 stroker cam options (street use) [Re: Dakota_Don] #87692
07/12/08 08:45 PM
07/12/08 08:45 PM
houston texas
gremlinsteve Offline
houston texas
get with scotty brown or fast68plymouth...dwayne porter.
they have some stuff that should work well.
i run scott brown myself.
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 408 stroker cam options (street use) [Re: gremlinsteve] #87693
07/13/08 02:50 PM
07/13/08 02:50 PM
Alton, IL
Alton, IL
I guess scott brown grinds his own cams?
thanks I will contact him also,
anyone else?
Re: 408 stroker cam options (street use) [Re: Dakota_Don] #87694
07/13/08 03:17 PM
07/13/08 03:17 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Scott picks the lobes and lsa he likes and has it ground. PM Fast68plymouth and let him get you what you need.
Re: 408 stroker cam options (street use) [Re: Dakota_Don] #87695
07/13/08 04:26 PM
07/13/08 04:26 PM
SoCal
Brian Hafliger Online content
Brian Hafliger  Online Content
SoCal
thanks
Don
What are you using for rocker arms? That has alot to do with which cam you should use. And valve springs??
Brian
Brian Hafliger
Re: 408 stroker cam options (street use) [Re: Brian Hafliger] #87696
07/13/08 08:25 PM
07/13/08 08:25 PM
Alton, IL
Alton, IL
1.5 ALU proform rocker, should I use 1.6 instead, the V-sprongs are the recomended ones for the cam listed above.. and have been checked.
Re: 408 stroker cam options (street use) [Re: Dakota_Don] #87697
07/14/08 07:50 AM
07/14/08 07:50 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I'd use the cam you have, personally, 1) I'm cheap, so why by another when you have a perfectly good cam and 2) for a street vehicle, that should be a nice cam for a 408, and probably give excellent idle-5500 RPM performance.
2017 Grand Cherokee Overland
Re: 408 stroker cam options (street use) [Re: patrick] #87698
07/14/08 08:53 AM
07/14/08 08:53 AM
New Mexico
dmerc Offline
dmerc  Offline
New Mexico
I have a cam very similar to yours in my 408 and it's a stump puller. Returned 18 MPG on it's first run also. Should be able to get a little more with some tuning.
Re: 408 stroker cam options (street use) [Re: dmerc] #87699
07/14/08 11:05 AM
07/14/08 11:05 AM
have your balance on that scat crank/rods/pistons checked IF you had it balanced by Scat. Scat doesnt match their pistons weights or the rod ends so you can be off a bunch on your balance job. They take the weights off the box (one weight for all the pistons) and these can be off significantly. Scats balance isnt up to performance industry standard (but probably better than a production job)
Re: 408 stroker cam options (street use) [Re: Dakota_Don] #87700
07/14/08 12:10 PM
07/14/08 12:10 PM
Milwaukee, WI
Prince_Valiant Offline
Milwaukee, WI
I agree with Patrick on this one...you could probably get away with a little more cam and be perfectly happy, but the difference in performance probably wouldn't justify the cost.
Should be a great engine with good low-end, VERY strong mid-range, and a decent pull to around 5200-5500 rpm.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph
1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD)
1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD)
1989 Shelby CSX #500/500
Re: 408 stroker cam options (street use) #87701
07/14/08 12:18 PM
07/14/08 12:18 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You could go custom but you dont have to. You have one that will work. I also run the Crane hydraulic H302-2 (an older split pattern) with good results. But your static ratio is too high for smaller "nice idle" cams. At least if it's a true 10:1 with those heads. The H302-2 idles at 850rpm w/ 13" of vacuum in gear with an 870VS Avenger carb, small tube headers, and dished pistons at 0 deck making 9.5:1 true static, and 8.25:1 dynamic. In your Dak it would run low 12s with 3.55s if you could stick it. The 3800lbs+ E body it's in has run 105+ and mid13s with a 2.6 short time, 3.23s, and zero traction.
Re: 408 stroker cam options (street use) [Re: moper] #87702
07/14/08 01:52 PM
07/14/08 01:52 PM
Dirty South, MS
mopowered Offline
mopowered  Offline
Dirty South, MS
Now thats an understatement!
Re: 408 stroker cam options (street use) #87703
07/14/08 09:01 PM
07/14/08 09:01 PM
Alton, IL
Alton, IL
already done, allied moter sports (strokerkits.com) ballanced my stuff, ok seem maybe i will keep the comp cam, and just install new lifters.. the old ones look fine, only ran them during a break in, but i beleive coolant mixed with oil ran trough them, so i dont know if they are anygood or not..
thanks for the input
Re: 408 stroker cam options (street use) [Re: moper] #87704
07/14/08 09:03 PM
07/14/08 09:03 PM
Alton, IL
Alton, IL
according to allied Motor sports, it will be a 10.2 CR with a 40 quench area.. im not sure what the deck height or what pistons were used..I let them do all the matching and CnC machining..
