Trans Fluid Level Cold ? #876849
12/10/10 03:42 PM
12/10/10 03:42 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
Hi, I am Chasing a Problem With A 727, & Need To Know What Level On The Dipstick Should Read Cold, Engine Not Running. Thanks, Tom.
Re: Trans Fluid Level Cold ? [Re: Tom Fox] #876850
12/10/10 04:08 PM
12/10/10 04:08 PM
Newark,Ohio
kissmyaspen Offline
kissmyaspen  Offline
Newark,Ohio
Engine needs to be running and in nuetral. So that the fluid is being picked up and pumped through the trans like it should be.
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: Trans Fluid Level Cold ? [Re: kissmyaspen] #876851
12/10/10 04:52 PM
12/10/10 04:52 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
as I always thought but learned with a power glide there's very little if any difference hot ,cold or running.
After checking running and hot it was rechecked when cold and sitting. maybe 1/2 pt on the stick ? now I know where it need be running or not
I assume the running part is to insure all the passesges and valve body are filled.
home of the
Sox and Martin Hemi Duster
Re: Trans Fluid Level Cold ? [Re: HEMIFRED] #876852
12/10/10 05:09 PM
12/10/10 05:09 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
I need to Know The Level Cold And NOT Running.
Re: Trans Fluid Level Cold ? [Re: Tom Fox] #876853
12/10/10 05:33 PM
12/10/10 05:33 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Fill it to the full level mark on the dip stick,that will be close enought to get you going. Most of the time I do mine that way & then make a run & come back & check it. I fill my TQ before installing it & never have had to add over a 1/2 qt. doing it that way. Hope this helps.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Trans Fluid Level Cold ? [Re: MRMOPAR622] #876854
12/10/10 05:35 PM
12/10/10 05:35 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Even if you did not fill your TQ you still should not be over a QT low.
Re: Trans Fluid Level Cold ? [Re: Tom Fox] #876855
12/10/10 05:44 PM
12/10/10 05:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Cold level will depend on the size of the converter and how much of it has drained into the pan.
Re: Trans Fluid Level Cold ? [Re: John_Kunkel] #876856
12/10/10 06:01 PM
12/10/10 06:01 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
What are ya doing, starting a fresh trans? If so, I usually start with 5 qts, start it up, throw it in neutral, then run it through the gears, park to low, park to 2nd, park to 3rd, then neutral, let it set for a few seconds in neutral, then check and add untill full. most kitted VBodies will show the same reading in park and neutral.
Kasey
Re: Trans Fluid Level Cold ? [Re: Moparnut426] #876857
12/10/10 09:39 PM
12/10/10 09:39 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
Well it seemed like a simple request.
Re: Trans Fluid Level Cold ? [Re: Tom Fox] #876858
12/11/10 01:00 AM
12/11/10 01:00 AM
Amherst,NY
challengermike Offline
Amherst,NY
Its not that simple though,it all depends on how much drains back into the pan when sitting.I dont think anyone would know that answer.It will read higher on the stick than the full mark.It will also be higher than the linkage seal if this helps any.
Re: Trans Fluid Level Cold ? [Re: challengermike] #876859
12/11/10 01:52 AM
12/11/10 01:52 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
Mine does that...reads higher when off and cold (depends on how long it's been sitting).
Re: Trans Fluid Level Cold ? [Re: Tom Fox] #876860
12/11/10 03:37 AM
12/11/10 03:37 AM
Two to three inches above the full mark seems reasonable. I always run my trans. so there at or below the add mark on the dipstick runninng when cold, I do run the deep Mopar trans pan so anytime the fluid shows on the dipsticks there is at least three quarts in the pan while running. I wouldn't be suprised if the fluid would be higher than mine if you had the fluid level sitting at the full mark when hot
