Re: Trans Fluid Level Cold ?
[Re: Tom Fox]
#876850
12/10/10 04:08 PM
12/10/10 04:08 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
Engine needs to be running and in nuetral. So that the fluid is being picked up and pumped through the trans like it should be.
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
[Re: Tom Fox]
#876853
12/10/10 05:33 PM
12/10/10 05:33 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Fill it to the full level mark on the dip stick,that will be close enought to get you going. Most of the time I do mine that way & then make a run & come back & check it. I fill my TQ before installing it & never have had to add over a 1/2 qt. doing it that way. Hope this helps.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: Tom Fox]
#876855
12/10/10 05:44 PM
12/10/10 05:44 PM
Posts: 25,877 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Cold level will depend on the size of the converter and how much of it has drained into the pan.
[Re: John_Kunkel]
#876856
12/10/10 06:01 PM
12/10/10 06:01 PM
Posts: 12,011 Finally a HUSKER again
Moparnut426
What are ya doing, starting a fresh trans? If so, I usually start with 5 qts, start it up, throw it in neutral, then run it through the gears, park to low, park to 2nd, park to 3rd, then neutral, let it set for a few seconds in neutral, then check and add untill full. most kitted VBodies will show the same reading in park and neutral.
Kasey
[Re: challengermike]
#876859
12/11/10 01:52 AM
12/11/10 01:52 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Its not that simple though,it all depends on how much drains back into the pan when sitting.I dont think anyone would know that answer.It will read higher on the stick than the full mark.It will also be higher than the linkage seal if this helps any.
Mine does that...reads higher when off and cold (depends on how long it's been sitting).
