Hood scoops/cold air induction solutions............... #874986
12/08/10 08:49 PM
12/08/10 08:49 PM
State of confusion
Thumperdart Offline OP
State of confusion
After talking to Mike(Mr. P-body)we came to the conclusion that my hood scoop is creating an issue as fuel is splashed all over my carbs after a pass. It`s a 5 1/2" 6-pack scoop that`s not really up in the air stream so I was considering getting air through the grill or lower vallance through 4" ducts Ford Thunderbolt style. This is a street car so a tall functional scoop is out of the question both legally and visually...........anyone run that set up and did you see an improvement. By the way, Mike will forget more than I`ll ever know.
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #874987
12/08/10 09:00 PM
12/08/10 09:00 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
There is a site that sells fiberglass hood scoops. They also list some type of duct work that funnels air into a cowl hood but from the front . I will go search and see if I can dig it up
home of the
Sox and Martin Hemi Duster
Re: Hood scoops/cold air induction solutions............... [Re: HEMIFRED] #874988
12/08/10 09:11 PM
12/08/10 09:11 PM
State of confusion
State of confusion
Sounds great............thankxxx Fred........
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #874989
12/08/10 10:14 PM
12/08/10 10:14 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Re: Hood scoops/cold air induction solutions............... [Re: Mr.Yuck] #874990
12/08/10 10:15 PM
12/08/10 10:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
just saying
Re: Hood scoops/cold air induction solutions............... [Re: HEMIFRED] #874991
12/08/10 10:21 PM
12/08/10 10:21 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I think this is what Fred was talking about:
http://www.ramairbox.com/
Re: Hood scoops/cold air induction solutions............... [Re: Quicksilver440] #874992
12/08/10 11:20 PM
12/08/10 11:20 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Are you using a air filter?
Re: Hood scoops/cold air induction solutions............... [Re: ademon] #874993
12/08/10 11:22 PM
12/08/10 11:22 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Mopar Performance
Re: Hood scoops/cold air induction solutions............... [Re: Quicksilver440] #874994
12/08/10 11:25 PM
12/08/10 11:25 PM
northeast ohio
mkdart Online content
mkdart  Online Content
northeast ohio
Like this? 4 inch tube though inner fender,to radiator core support. I think the air may be turbulent at the inlet,but its cooler. Mike
Re: Hood scoops/cold air induction solutions............... [Re: Mr.Yuck] #874995
12/08/10 11:25 PM
12/08/10 11:25 PM
State of confusion
State of confusion
just saying
I highly doubt your cowl is "functional" in terms of forcing air into your carb.......could be wrong.
Re: Hood scoops/cold air induction solutions............... [Re: ademon] #874996
12/08/10 11:26 PM
12/08/10 11:26 PM
State of confusion
State of confusion
Yes, a 14x3 k&n sealed to the hood.
Re: Hood scoops/cold air induction solutions............... [Re: mkdart] #874997
12/08/10 11:27 PM
12/08/10 11:27 PM
State of confusion
State of confusion
Thats kinda what I was thnking........
Re: Hood scoops/cold air induction solutions............... [Re: mkdart] #874998
12/08/10 11:27 PM
12/08/10 11:27 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
what I saw was more like an addtion to the hood.It had one side open that looked like it rested against the underside of the hood
home of the
Re: Hood scoops/cold air induction solutions............... [Re: HEMIFRED] #874999
12/08/10 11:28 PM
12/08/10 11:28 PM
State of confusion
State of confusion
I`d love to see what you`re refering to.
Re: Hood scoops/cold air induction solutions............... [Re: moparniac] #875000
12/08/10 11:29 PM
12/08/10 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What we had talked about was maybe bringing in a single
or double hose/tubing into the bottom of his sealed
off 6 pac pan then closing off the front of it(maybe
back in 3 " and painting it black so it looks normal)
yes he is running a filter which sticks up in the scoop
Re: Hood scoops/cold air induction solutions............... [Re: MR_P_BODY] #875001
12/08/10 11:53 PM
12/08/10 11:53 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i got a customer to build a thunderbolt style set up for his dual quad,inline,409.it did help mostly because he ran no filter when racing and now at least it wasn't sucking down hot air.there did not appear to be any draw backs just screened the 2 intakes-outer headlamp position.got a cowl now with a mickey thompson crossram
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Hood scoops/cold air induction solutions............... [Re: tex013] #875002
12/09/10 12:14 AM
12/09/10 12:14 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
This is a nice set up for a cowl hood. Sealed cool air from grille area and hot air from engine exits cowl. I like it.
Getting old just means you were smarter than some and luckier than others.
Re: Hood scoops/cold air induction solutions............... [Re: dannysbee] #875003
12/09/10 12:19 AM
12/09/10 12:19 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
DAT BE DA ONE
home of the
Re: Hood scoops/cold air induction solutions............... [Re: dannysbee] #875004
12/09/10 12:33 AM
12/09/10 12:33 AM
Oklahoma
silverfish Offline
silverfish  Offline
Oklahoma
That looks like it would work on my setup too. Thanks for posting that.
Re: Hood scoops/cold air induction solutions............... [Re: Thumperdart] #875005
12/09/10 12:45 AM
12/09/10 12:45 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I run the 3" Six-pak scoop and the carb responds to every single jet change so I assume it is working good. I talked to someone the other day that went from a six-pak hood to a big pro stock scoop, even with jetting the car didn't pick up. I was really surprised to hear that.
