Re: Hood scoops/cold air induction solutions...............
[Re: Thumperdart]
#874987
12/08/10 09:00 PM
12/08/10 09:00 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
There is a site that sells fiberglass hood scoops. They also list some type of duct work that funnels air into a cowl hood but from the front . I will go search and see if I can dig it up
home of the Sox and Martin Hemi Duster
[Re: Mr.Yuck]
#874990
12/08/10 10:15 PM
12/08/10 10:15 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
[Re: mkdart]
#874998
12/08/10 11:27 PM
12/08/10 11:27 PM
HEMIFRED
SOUTH JERSEY
what I saw was more like an addtion to the hood.It had one side open that looked like it rested against the underside of the hood
[Re: HEMIFRED]
#874999
12/08/10 11:28 PM
12/08/10 11:28 PM
Thumperdart
State of confusion
I`d love to see what you`re refering to.
[Re: moparniac]
#875000
12/08/10 11:29 PM
12/08/10 11:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What we had talked about was maybe bringing in a single or double hose/tubing into the bottom of his sealed off 6 pac pan then closing off the front of it(maybe back in 3 " and painting it black so it looks normal) yes he is running a filter which sticks up in the scoop
[Re: MR_P_BODY]
#875001
12/08/10 11:53 PM
12/08/10 11:53 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
i got a customer to build a thunderbolt style set up for his dual quad,inline,409.it did help mostly because he ran no filter when racing and now at least it wasn't sucking down hot air.there did not appear to be any draw backs just screened the 2 intakes-outer headlamp position.got a cowl now with a mickey thompson crossram Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#875002
12/09/10 12:14 AM
12/09/10 12:14 AM
Posts: 5,160 Texas
dannysbee
Texas
This is a nice set up for a cowl hood. Sealed cool air from grille area and hot air from engine exits cowl. I like it.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#875004
12/09/10 12:33 AM
12/09/10 12:33 AM
Posts: 858 Oklahoma
silverfish
Oklahoma
That looks like it would work on my setup too. Thanks for posting that.
[Re: Thumperdart]
#875005
12/09/10 12:45 AM
12/09/10 12:45 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I run the 3" Six-pak scoop and the carb responds to every single jet change so I assume it is working good. I talked to someone the other day that went from a six-pak hood to a big pro stock scoop, even with jetting the car didn't pick up. I was really surprised to hear that.
