Re: Hood scoops/cold air induction solutions...............
[Re: Thumperdart]
#874987
12/08/10 09:00 PM
12/08/10 09:00 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
There is a site that sells fiberglass hood scoops. They also list some type of duct work that funnels air into a cowl hood but from the front . I will go search and see if I can dig it up
home of the Sox and Martin Hemi Duster
[Re: Mr.Yuck]
#874990
12/08/10 10:15 PM
12/08/10 10:15 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
[Re: mkdart]
#874998
12/08/10 11:27 PM
12/08/10 11:27 PM
HEMIFRED
SOUTH JERSEY
what I saw was more like an addtion to the hood.It had one side open that looked like it rested against the underside of the hood
[Re: HEMIFRED]
#874999
12/08/10 11:28 PM
12/08/10 11:28 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
I`d love to see what you`re refering to.
[Re: moparniac]
#875000
12/08/10 11:29 PM
12/08/10 11:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
What we had talked about was maybe bringing in a single or double hose/tubing into the bottom of his sealed off 6 pac pan then closing off the front of it(maybe back in 3 " and painting it black so it looks normal) yes he is running a filter which sticks up in the scoop
[Re: MR_P_BODY]
#875001
12/08/10 11:53 PM
12/08/10 11:53 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
i got a customer to build a thunderbolt style set up for his dual quad,inline,409.it did help mostly because he ran no filter when racing and now at least it wasn't sucking down hot air.there did not appear to be any draw backs just screened the 2 intakes-outer headlamp position.got a cowl now with a mickey thompson crossram Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#875002
12/09/10 12:14 AM
12/09/10 12:14 AM
Posts: 5,160 Texas
dannysbee
Texas
This is a nice set up for a cowl hood. Sealed cool air from grille area and hot air from engine exits cowl. I like it.
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#875004
12/09/10 12:33 AM
12/09/10 12:33 AM
Posts: 858 Oklahoma
silverfish
Oklahoma
That looks like it would work on my setup too. Thanks for posting that.
[Re: Thumperdart]
#875005
12/09/10 12:45 AM
12/09/10 12:45 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I run the 3" Six-pak scoop and the carb responds to every single jet change so I assume it is working good. I talked to someone the other day that went from a six-pak hood to a big pro stock scoop, even with jetting the car didn't pick up. I was really surprised to hear that.
[Re: dannysbee]
#875007
12/09/10 10:24 AM
12/09/10 10:24 AM
Mr.Yuck
Brookeville, Md
mine won't look that nice but it will be sealed to the hood. An probably won't be a "ram-air" type.
[Re: Thumperdart]
#875010
12/10/10 03:52 AM
12/10/10 03:52 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Scoop/pan design, air pressure and flow do weird things. A friend had a '65 Satellite with a carb pan sealed '65 scoop on it. Car had some inconsistency issues and threw a real curve ball once in a while. He cut away some of the seal, made vents, and the car was a lot more consistent. Can't recall if it picked up also.
That`s my point.........lots of fuel splash on carb top and although it does respond to jetting, 98`s in the rear and 84`s up ft. w/a pv seems excessive to me AND others. After talking w/Mike we thaught it would be good to even extend what I have now and see if the wide band responds. I also thaught about drilling holes in the back of the scoop to release air.......something just don`t seem right and your buddy proved it by venting his. Thankxxxx guy`s.
Maybe its your air filter sticking up into the scoop and directly into the incoming air, creating a siphon on the bowl vents, maybe try a half round deflector on the front part of the air filter
[Re: Thumperdart]
#875011
12/10/10 05:12 AM
12/10/10 05:12 AM
Posts: 4,647 aotearoa
rebel
aotearoa
what carb are you running & any chance you could post a pic of your set up with the filter top removed?
[Re: Locomotion]
#875017
12/10/10 02:28 PM
12/10/10 02:28 PM
HEMIFRED
SOUTH JERSEY
I remember speaking to John Bauman when he was the one doing the testing on the snorkel. Chrysler was very specific as where to place the carbs in relationship to the scoop in differet areas. Much had to do with maintaining fuel flow as well as ram air
[Re: Thumperdart]
#875019
12/10/10 07:24 PM
12/10/10 07:24 PM
Posts: 1,238 North Cackilacky
sdaurity
North Cackilacky
I'll add this. I make alot of lexan boxes for hood scoops and we just cut a square hole in the cowl hood and let the lexan box hang out. prob 5 yrs ago when we made the 1st one it was sealed off on 5 sides front only open obviously. you could make a pass and I could see gas like it was floating/pulling out of the carb floating in the box abouve the carb. Drilled 4- 1/2 inch holes in the back of the scoop. Never done it again. don't ask me why. Just my experience.
One day I will have something cool here.
[Re: Thumperdart]
#875024
12/12/10 09:28 AM
12/12/10 09:28 AM
Posts: 151 N.E. Ohio
OhioGTX
N.E. Ohio
Not sure if thjis will help, but I have experienced similar issues and found that a stub-stack solved the problem. We basically determined that different signals were being given to the carb at the bleeds due to whatever was happeing with the air in that compressed space at speed..the snub stack helped quite a bit...as a note we experienced this when the carbs were very close to the scoop...worst case it is a cheap experiment..as an alternative, open the back of the scoop ( drill holes / rais rear of hood etc.) allowing for a clean flow of air over the carb...maybe due both...
68 GTX, 9.38 at 144, Best Machine 540..
