Best Mini Alternator???
#874785
12/08/10 05:32 PM
12/08/10 05:32 PM
Posts: 984 San Diego CA
65 Hemi
San Diego CA
What is the best mini alternator to use on a BBM low mount for a street/strip car?
Doug
MOPAR or NO CAR!!! 1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas 1964 Dodge Polara 582" Indy alum Block 426-1RA heads, 1933 Plymouth PE all Steel, LT1 4L60E 1959 Plymouth Savoy 33,000 mile survivor Old cars are never done. They are ongoing projects!
Re: Best Mini Alternator???
[Re: 65 Hemi]
#874786
12/08/10 05:49 PM
12/08/10 05:49 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Honestly,,, I have used a starter from a 90s era dodge magnum with great success. Thats on a 13.5 comp big block. SORRY IM DUMB YOU MEANT ALTORNATOR KAsey
[Re: Moparnut426]
#874787
12/08/10 06:27 PM
12/08/10 06:27 PM
Posts: 836 Missouri
galen
Missouri
I have only been using it for about a month. So far so good. I got a Denso 1-wire mini for 109$. http://www.rareelectrical.com Look under Racing. I was happy with what I got for the price just wish I had more time on it to give feedback.
[Re: Moparnut426]
#874788
12/08/10 06:30 PM
12/08/10 06:30 PM
Posts: 976 Woodstock , Georgia
Mopar_racer_99
Woodstock , Georgia
I tried the mini alts, but they only put out 35-50 amps at full tilt and found we draw too many amps, we are running a delco 10si case set up for 140 amps now, it puts out 100 amps at idle cost 85 dollars. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
[Re: Mopar_racer_99]
#874789
12/08/10 07:07 PM
12/08/10 07:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been using a Chrysler production Denso for years now... 85 amp, I did make my pulley for it but I dont know if you can buy a pulley or not(never looked)
[Re: 65 Hemi]
#874791
12/08/10 07:23 PM
12/08/10 07:23 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
In my opinion...East Coast Electrical
[Re: 65 Hemi]
#874792
12/08/10 07:35 PM
12/08/10 07:35 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I run a Denso from a Toyota truck that I snagged from the cash for clunkers program It cranks 80 amps and provides 15 volts with the fan,water pump,and fuel pump running Works perfectly with a few spacers and Andy's bracket kit Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Blucuda413]
#874794
12/08/10 09:29 PM
12/08/10 09:29 PM
fourgearsavoy
Rittman Ohio
I think it was an 89 with a 22R 4 cylinder engine. You can order one direct from the Denso website. AndyF recommends a Powermaster with his kit but I got mine for free so I made it work. Gus
