Best Mini Alternator??? #874785
12/08/10 05:32 PM
12/08/10 05:32 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
What is the best mini alternator to use on a BBM low mount for a street/strip car?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: Best Mini Alternator??? [Re: 65 Hemi] #874786
12/08/10 05:49 PM
12/08/10 05:49 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Honestly,,,
I have used a starter from a 90s era dodge magnum with great success.
Thats on a 13.5 comp big block.
SORRY IM DUMB YOU MEANT ALTORNATOR
KAsey
Re: Best Mini Alternator??? [Re: Moparnut426] #874787
12/08/10 06:27 PM
12/08/10 06:27 PM
Missouri
galen Offline
galen  Offline
Missouri
I have only been using it for about a month. So far so good. I got a Denso 1-wire mini for 109$. http://www.rareelectrical.com Look under Racing. I was happy with what I got for the price just wish I had more time on it to give feedback.
Re: Best Mini Alternator??? [Re: Moparnut426] #874788
12/08/10 06:30 PM
12/08/10 06:30 PM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
I tried the mini alts, but they only put out 35-50 amps at full tilt and found we draw too many amps, we are running a delco 10si case set up for 140 amps now, it puts out 100 amps at idle cost 85 dollars. John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Best Mini Alternator??? [Re: Mopar_racer_99] #874789
12/08/10 07:07 PM
12/08/10 07:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been using a Chrysler production Denso for years
now... 85 amp, I did make my pulley for it but I
dont know if you can buy a pulley or not(never looked)
Re: Best Mini Alternator??? [Re: galen] #874790
12/08/10 07:13 PM
12/08/10 07:13 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Thank Galen. I just ordered the same unit.
Doug
MOPAR or NO CAR!!!
Re: Best Mini Alternator??? [Re: 65 Hemi] #874791
12/08/10 07:23 PM
12/08/10 07:23 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
In my opinion...East Coast Electrical
Re: Best Mini Alternator??? [Re: 65 Hemi] #874792
12/08/10 07:35 PM
12/08/10 07:35 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I run a Denso from a Toyota truck that I snagged from the cash for clunkers program It cranks 80 amps and provides 15 volts with the fan,water pump,and fuel pump running
Works perfectly with a few spacers and Andy's bracket kit
Gus
64 Plymouth Savoy
Dana 60
Re: Best Mini Alternator??? [Re: fourgearsavoy] #874793
12/08/10 09:11 PM
12/08/10 09:11 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
fourgear, what Toyo truck did the alt come from??
Re: Best Mini Alternator??? [Re: Blucuda413] #874794
12/08/10 09:29 PM
12/08/10 09:29 PM
Rittman Ohio
Rittman Ohio
I think it was an 89 with a 22R 4 cylinder engine.
You can order one direct from the Denso website.
AndyF recommends a Powermaster with his kit but I got mine for free so I made it work.
Gus
64 Plymouth Savoy
Dana 60
Re: Best Mini Alternator??? [Re: 65 Hemi] #874795
12/09/10 10:58 PM
12/09/10 10:58 PM
Commerce City .Co USA
chargerD Offline
chargerD  Offline
60 amp denso from rare electric. Got mine off ebay.
