Re: engine temperature
[Re: Moparnut426]
#874668
12/08/10 07:32 PM
12/08/10 07:32 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
You honestly go through that whole deal before every drive?
Kasey
I know racer who do, it depends on how long it has sat bewtween rounds and the outside air temps NHRA requires that you run the car on jackstands, not on a jcak. I prefer to drive the car around in the pits for a while( I have a trans oil, engine oil and water temp gauge inthe car) to warm all the fluids up to above 100 F, especially when it is below 70 F outside, which is quite common up here in central Oregon
[Re: Cab_Burge]
#874669
12/08/10 08:03 PM
12/08/10 08:03 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
moparnut426, I should have put the 1st time when I warm the car up. I want not just the water or oil temp. to be up but everything else in the engine. This is a must do if running aluminum rods. Mr Cab warming a dragster up on jack-stands is not a good idea,at least on a hard-tail. When Woody Mays & Bill Key were building my 2nd dragster,a cutomer of there's who had just picked the car put his engine & everything in and put it on jack stands in his shop with the door closed.He was stitting in it,but could not stop it before it went tru the door. I think the way the T/F & F/C get away with it is the way they raise them up both front & back on the frames(not 100% sure about that).But I know putting the jack stands under the rear-end of a hard tail car is not a good idea.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: oldtimer5151]
#874671
12/09/10 01:59 AM
12/09/10 01:59 AM
Posts: 4,209 New York
polyspheric
New York
If you can`t say something good, don`t say nothing at all
And that's why we're still living in this cave, eating dead rats.
Boffin Emeritus
[Re: HEMIFRED]
#874673
12/09/10 02:58 AM
12/09/10 02:58 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I just drain the oil and put it in a non-stick pasta pot and let it sit on the kitchen stove for 25 min at about a number 6 setting
do you add any garlic
Thats how he sautes his onions and some mushrooms
