engine temperature #874647
12/08/10 01:18 PM
12/08/10 01:18 PM
Aubrey, Texas
O
oldtimer5151 Offline OP
O
Aubrey, Texas
I saw some freeze plugs that have an electric element and they warm the coolant in cold weather. I would like to use these to have my coolant warm and install a oil stick heater to warm the oil. How do you warm everything prior to start-up?
Re: engine temperature [Re: oldtimer5151] #874648
12/08/10 01:33 PM
12/08/10 01:33 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
this year I just installed a heater in the oil pan. I have used a light under the hood in the past when it was emergency
home of the
Sox and Martin Hemi Duster
Re: engine temperature [Re: oldtimer5151] #874649
12/08/10 01:37 PM
12/08/10 01:37 PM
How do you warm the car up? I start the up Preheating the oil does reduce the time to warm it (oil) up Many racers have found that a cool block with hot oil is faster than cool oil or hot oil and hot coolant. I run 5W20Wt oil for that reason, thin oil does not rob as much power as the thicker oils do when cold or below 130F, been there doen that
Re: engine temperature [Re: Cab_Burge] #874650
12/08/10 01:53 PM
12/08/10 01:53 PM
Aubrey, Texas
O
O
Aubrey, Texas
A warm engine at start up has the metal warm and closes the clearances. The cylinders,rings,etc.are all enlarged and there is less wear and stress on a warm engine at start up only. I have not tried to warm my oil but I bought a external magnetic oil pan heater to try. How do you circulate the oil after it is warm on the bottom of the pan? Just start the engine when it is what temperature?
Re: engine temperature [Re: oldtimer5151] #874651
12/08/10 01:57 PM
12/08/10 01:57 PM
Oregon City, OR
Baxter61 Offline
Baxter61  Offline
Oregon City, OR
I just drain the oil and put it in a non-stick pasta pot and let it sit on the kitchen stove for 25 min at about a number 6 setting
Re: engine temperature [Re: Baxter61] #874652
12/08/10 02:02 PM
12/08/10 02:02 PM
Aubrey, Texas
O
O
Aubrey, Texas
Thumper the rabbit in Bambi made a profound statement that I have found so true. " If you can`t say something good, don`t say nothing at all."
Re: engine temperature [Re: oldtimer5151] #874653
12/08/10 02:15 PM
12/08/10 02:15 PM
I have built and raced NHRA stock motors, the high end go for broke racers, especially on a heads up race, will have oil heaters glued onto the oil pan(no dipstick heaters that I know of )and used them for 20 to 30 minutes before making the run. I have seen some of them pour ice water into the motors jst before pulling out of the staging lanes, they also soak the intake manifold with ice cold towels to get them as cold as they can I have dyno tested a bunch of pump gas and race gas motors, never saw a real differences in power using the thin oils(5W20 or 5W30 wt) in oil temps from 110 F to 210 F, similar results on water temps, no real power gains or losses from 110F to 180 F on N/A motors on a well tuned motor Manifold inlet temps do make a big difference in the same tests, cold (below 110 F) is way better
Re: engine temperature [Re: oldtimer5151] #874654
12/08/10 04:04 PM
12/08/10 04:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running a alum block and or alum rods.... the
dip stick header that I seen years ago(in Alaska)
would burn the oil... the freeze plug heaters work but
you better have plenty of time... I myself dont fire
up my car when its below about 55*... E-85 (summer
grade) doesnt like to fire... but being that I run a
dry sump the first time I fire up I pull the belt and
spin the pump to oil it
Re: engine temperature [Re: Cab_Burge] #874655
12/08/10 04:04 PM
12/08/10 04:04 PM
Aubrey, Texas
O
O
Aubrey, Texas
Thanks for the help!
Re: engine temperature [Re: oldtimer5151] #874656
12/08/10 04:25 PM
12/08/10 04:25 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Im sure that you could make a large -8 or 10 fitting at the bottom of the pan, then run that to a diffy oil pump, and just circulate that through a cool can with a warmer on it. Should be very simple, and easy to do, the oil can doesnt have to be very large as the circulation should ensure all the oil will be warm. You could use a NOS bottle warmer to get it to your desired temp.
KAsey
Re: engine temperature [Re: MR_P_BODY] #874657
12/08/10 04:50 PM
12/08/10 04:50 PM
Aubrey, Texas
O
O
Aubrey, Texas
It is cast iron block with aluminum heads. I called the manufacture of the freeze plug and pan heater and he said that it would not take to long to heat the motor. I guess that I should take a heat gun and check it while it is heating. I live in Texas and ,while it is not cold here as up there, I like to have the motor warm when I arrive at the races, and only have to make a brief drive thru the pits to warm everything else. Just getting old and grumpy!!
Re: engine temperature [Re: oldtimer5151] #874658
12/08/10 04:51 PM
12/08/10 04:51 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Instead of using those block heaters you can also buy inline coolant heaters that mount in the rad hoses. Just easier to install, especially if the engine is in the car.
codfish
Re: engine temperature [Re: codfish] #874659
12/08/10 04:53 PM
12/08/10 04:53 PM
Aubrey, Texas
O
O
Aubrey, Texas
Who sells Them?
Re: engine temperature [Re: codfish] #874660
12/08/10 04:54 PM
12/08/10 04:54 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Going through all-that .. HEATING the water and oil ...without an ACCUsump pre-oiler ?
Re: engine temperature [Re: dOoC] #874661
12/08/10 04:57 PM
12/08/10 04:57 PM
Aubrey, Texas
O
O
Aubrey, Texas
Remember, I have a 383cu. If I had a larger motor,maybe.
Re: engine temperature [Re: oldtimer5151] #874662
12/08/10 04:59 PM
12/08/10 04:59 PM
Moparnut426 Offline
Moparnut426  Offline
CATS brand sells the hose inline pumps. Had one on my ol dodge and she would start in 20+ below zero nebraska windy cold winters like clockwork. Pluss my heater was hot right off the bat.
I did go through a few windshields in the ol powerwagon with that thing though.
KAsey
Re: engine temperature [Re: oldtimer5151] #874663
12/08/10 05:18 PM
12/08/10 05:18 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Who sells Them?
Here's an example of one. This one actually goes in the heater hose, IF you have one. But the rad hose type is similar. Here in Canada, any parts place has them in stock. $30 or so usually.
http://cgi.ebay.com/ebaymotors/Kats-Inli...=item35ae829b84
codfish
Re: engine temperature [Re: oldtimer5151] #874664
12/08/10 05:20 PM
12/08/10 05:20 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
BIG or small ....pre-oiling is a better prsctice than PREheating your water and oil ..
Re: engine temperature [Re: oldtimer5151] #874665
12/08/10 05:27 PM
12/08/10 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The thing with all those block heaters is they are
110 volt so you need a generator or plug them in at
home to warm it up
Re: engine temperature [Re: dOoC] #874666
12/08/10 05:31 PM
12/08/10 05:31 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I use a Master Lube to pre-oil my engine before start ups. I like to pre lube my engine,then fire it up & jake the rear tires of the ground & with me in the car,put it in gear @ idle let the engine & drive train all warm up together. When the engine temp. get to 180-190 I shut it off & let it heat soak for about 30 mins.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
