Complete lack of trust in previous shop's block work... #873701
12/07/10 06:39 PM
12/07/10 06:39 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Write it off to paranoia or just having too many experiences w/ paying machine shops for "quality" work and not getting what I've paid for. Regardless, I hauled my "ready to assemble" 448 block done by another shop some years back in a different part of the same state (not close to me) over to the local shop that did the freshen-up work on my 452's block this summer. I asked them to give it the and double-check the work.
1. Check bore sizes, concentricity, and verify the hone job was actually done WITH torque plates (been burned on that one already).
2. Check the aluminum main cap installation to verify main bore sizing and concentricity.
3. Correct the CRAPPY chamfer job done on the top of the bores that looks like my 6-year old did it w/ a rat-tailed file.
4. Remove what's left of the old dipstick tube that's still stuck in the block.
There are actually a few more items on the list I provided w/ the block, but you get the idea. Until I find out what the story is on this, I'm not making any more moves towards building anything w/ this block.
EDIT: I'll also mention that I do own the tools required to do a good bit of this checking, but do this type of stuff so infrequently that I'm looking for an experienced hand to do the measurements.
Re: Complete lack of trust in previous shop's block work... [Re: BradH] #873702
12/07/10 06:47 PM
12/07/10 06:47 PM
AndyF Offline
AndyF  Offline
Bad machine work is a bummer. Not only do you pay for the machine work, but sometimes the actual parts are ruined too. So you end up paying for everything multiple times over. I was lucky to find a good machine shop to work with years ago. It isn't a fancy shop but the guy takes his time and does it right.
Re: Complete lack of trust in previous shop's block work... [Re: AndyF] #873703
12/07/10 07:38 PM
12/07/10 07:38 PM
BradH Offline OP
BradH  Offline OP
Example: The block in question has already been bored .040" over since they said it didn't clean up at .030". And they've already done the install on the old-style aluminum main caps. If the bore work is crap, I'm still sitting on a set of .040" pistons, but the block "could" be taken out again. But what happens if they hosed the main cap installation? Does the block automatically become a boat anchor?
This stuff drives me effing nutz sometimes.
Re: Complete lack of trust in previous shop's block work... [Re: AndyF] #873704
12/07/10 07:43 PM
12/07/10 07:43 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
yea i know that feeling all to well myself. had a shop build my 340 years ago they charged my 320.00 for a comp cam and lifters and when i got the motor going ran like a pos..... took it apart and took the block over to another shop cylinder out of round and a few other things so im kinda funny now as to who does the work...
Re: Complete lack of trust in previous shop's block work... [Re: AndyF] #873705
12/07/10 07:44 PM
12/07/10 07:44 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Went through that a couple years ago with "The best Mopar guy in Chicago".
1. Put one rod/piston into block-Piston stuck above deck .250". Guy ordered wrong pistons. Took 4 weeks to get right pistons.
2. Decked the block with the alignment dowels still in the block. Had to drill them out.
3. Went to install cam- Bearings so tight cam would not go in. (He had the cam specifically so he could fit the bearings)
Trust no one.
Re: Complete lack of trust in previous shop's block work... [Re: earthmover] #873706
12/07/10 07:48 PM
12/07/10 07:48 PM
organ
maximum entropy Offline
organ
this is why i've invested in my own measuring equipment- been burned! i've found a hole in the wall one man shop who knows i double check his work, and he puts everything exactly where i want it. i love this guy!
Re: Complete lack of trust in previous shop's block work... [Re: BradH] #873707
12/07/10 09:43 PM
12/07/10 09:43 PM
Delray beach, Florida
P
Performance Only Offline
P
nothing surprises me anymore. i just finished checking and correcting a block for another Moparts member. he already had the block to two other shops. the first one messed it up and by measuring things himself, he saw some disturbing things. he took it to a second shop to fix the first shops mistakes. to say he was disappointed when he got it back would be an understatement.
when i started checking things i found the cylinders were hour glass shaped as much as .0045" the decks (which were already cut twice) were off front to rear by .005 and side to side by almost .007" to make matters worse, they weren't machined 45 degrees to the crank centerline. what a mess.
it's amazing what shows up when you put a block in a CNC machining center. the nice thing is it sure makes things easier to correct.
machine shop owner and engine builder
Re: Complete lack of trust in previous shop's block work... [Re: BradH] #873708
12/07/10 09:49 PM
12/07/10 09:49 PM
NC
440Jim Offline
440Jim  Offline
NC
I had my 511 CID low deck done at Weston Machine in NJ. I was so happy with the result, I took my old 471 block to them a few years ago to have the same aluminum cap treatment and give the bores a fresh hone for new rings.
When I picked it up, they said; "Was this honed with torque plates originally?". It didn't appear so when they freshened it. The previous shop that did it seemed fine, and I trusted them, but that made me wonder if they actually had a BB Mopar torque plate...
Re: Complete lack of trust in previous shop's block work... [Re: Performance Only] #873709
12/07/10 09:51 PM
12/07/10 09:51 PM
organ
organ
that's the shizznitt right there!
Re: Complete lack of trust in previous shop's block work... [Re: Performance Only] #873710
12/07/10 09:53 PM
12/07/10 09:53 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
True, but there are putzs running them too Dan. Some people can screw up anything with anything.
Re: Complete lack of trust in previous shop's block work... [Re: Hot 340] #873711
12/07/10 10:15 PM
12/07/10 10:15 PM
P
P
that's probably true
as unfortunate as it might be, it seems there are a lot of machinists that just don't care, and just as many that do, but have old worn out equipment that can't hit the numbers. when you get the best of both you thank them and treat them well, this industry is a dying breed.
Re: Complete lack of trust in previous shop's block work... [Re: Performance Only] #873712
12/07/10 10:38 PM
12/07/10 10:38 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Does anyone provide a check sheet with all measurements recorded after a machining job anymore?
I wouldn't trust Warren Johnson to give me a block without a check sheet that I could verify with my own tools before assembly.
Re: Complete lack of trust in previous shop's block work... [Re: cgall] #873713
12/07/10 10:47 PM
12/07/10 10:47 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
my guy gave me 1
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Complete lack of trust in previous shop's block work... [Re: dusturbd340W5] #873714
12/07/10 10:48 PM
12/07/10 10:48 PM
Q
Quicktree Offline
Quicktree  Offline
Q
my guy gave me 1
that really sounds weird
Re: Complete lack of trust in previous shop's block work... [Re: Quicktree] #873715
12/07/10 10:50 PM
12/07/10 10:50 PM
Kissimmee Fl.
Kissimmee Fl.
maybe to you but he asked a ? and I answered that ?
Re: Complete lack of trust in previous shop's block work... [Re: Quicktree] #873716
12/07/10 10:50 PM
12/07/10 10:50 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
my guy gave me 1
oh man. just stop it
Re: Complete lack of trust in previous shop's block work... [Re: cgall] #873717
12/07/10 10:50 PM
12/07/10 10:50 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
MY MOTOR WAS DONE by mendezmotorsports, he told me my motor would run 10.20's and the damn thing runs 9.80's. now i got to get certified and all that stuff
WAXER
Re: Complete lack of trust in previous shop's block work... [Re: QWK_ENUF] #873718
12/07/10 10:51 PM
12/07/10 10:51 PM
Kissimmee Fl.
Kissimmee Fl.
that's a good problem to have
Re: Complete lack of trust in previous shop's block work... [Re: QWK_ENUF] #873719
12/07/10 10:58 PM
12/07/10 10:58 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Not good, Qwik..
He just cost you a bunch more money than you had planned for!!!
Ignorance is bliss I guess, or I've gotten really lucky, never had a machine work based problem yet...
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Complete lack of trust in previous shop's block work... [Re: MoparBilly] #873720
12/08/10 12:20 AM
12/08/10 12:20 AM
BradH Offline OP
BradH  Offline OP
Ignorance is bliss I guess...
In my case, I think it's how I got into this situation in the first place starting back around 1998.
