torqueflite NSS? #873012
12/06/10 03:04 PM
12/06/10 03:04 PM
San MARcoS, Tx
slant666 Offline OP
slant666  Offline OP
San MARcoS, Tx
i have a 77 volare 225\6 i've been rebuilding pretty much from scratch. i tracked down the wiring harness to the nss, but i cannot figure out where to plug it into the rest of the harness. i've looked at a couple wiring diagrams and i just cannot figure it out. i must sound retarded, but this is the last thing i need to hook up so i can have key ignition/reverse lights/gauges.
Re: torqueflite NSS? [Re: slant666] #873013
12/06/10 03:12 PM
12/06/10 03:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Wire plug comming out of the firewall by the passenger side of the big bulkhead connecter?
Re: torqueflite NSS? [Re: stumpy] #873014
12/06/10 03:25 PM
12/06/10 03:25 PM
San MARcoS, Tx
slant666 Offline OP
slant666  Offline OP
San MARcoS, Tx
nosir. there's a small cluster of connectors on the firewall b/t the fender and the brake booster. i have a push button hot-wired in there b/c i havn't figured where to properly connect.
Re: torqueflite NSS? [Re: slant666] #873015
12/06/10 04:01 PM
12/06/10 04:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Well then you need a wiring diagram , if you have something connected there wit ha push button between to wires then that would be where it goes I would guess ? I had a 78 LeBaron , , M body , the connector , if I remember right , was on the pass side of the engine compartment on the firewall .... I THINK .
Re: torqueflite NSS? [Re: JohnRR] #873016
12/06/10 04:09 PM
12/06/10 04:09 PM
San MARcoS, Tx
slant666 Offline OP
slant666  Offline OP
San MARcoS, Tx
i have a wiring diagram that has gotten me this far and chilton that i will put in my camp supplies as extra tp (worthless), there is nothing on the passenger side except the ignition module and the starter relay... so i guess my question is really where the hell is the bulkhead on a 77 plymouth volare \6?
Re: torqueflite NSS? [Re: slant666] #873017
12/06/10 04:40 PM
12/06/10 04:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The bulkhead connecter is the one with all the wires connected to it that lead to the inside of the car. It's the big wiring block on the firewall.
Re: torqueflite NSS? [Re: stumpy] #873018
12/06/10 04:57 PM
12/06/10 04:57 PM
San MARcoS, Tx
slant666 Offline OP
slant666  Offline OP
San MARcoS, Tx
i don't see any large interface going into the firewall. just a couple smaller ones.
i have a big blown up printout of this:
http://www.mymopar.com/downloads/1976/76VolareA.JPG
http://www.mymopar.com/downloads/1976/76VolareB.JPG
but i don't see the bulkhead connector on the firewall.
Re: torqueflite NSS? [Re: slant666] #873019
12/06/10 05:10 PM
12/06/10 05:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How about taking a picture of your firewall and we should be able to point out where you need to be looking.
Re: torqueflite NSS? [Re: stumpy] #873020
12/06/10 05:48 PM
12/06/10 05:48 PM
San MARcoS, Tx
slant666 Offline OP
slant666  Offline OP
San MARcoS, Tx
here's a link to photos of the firewall and a pic of the plugs coming out of the nss plug. did it they change much from model to model?
http://s202.photobucket.com/albums/aa147/culikhan/car%20stuff/
Re: torqueflite NSS? [Re: slant666] #873021
12/06/10 05:51 PM
12/06/10 05:51 PM
Under My Car
Mopar_Country Offline
Under My Car
It should be right behind the engine, multiple wires.
Re: torqueflite NSS? [Re: slant666] #873022
12/06/10 05:57 PM
12/06/10 05:57 PM
Nevada
Darter6 Offline
Darter6  Offline
Nevada
I thought for sure that the NSS wire went from the trans to the starter relay.
Re: torqueflite NSS? [Re: Mopar_Country] #873023
12/06/10 05:58 PM
12/06/10 05:58 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Neutral Safety Switch should be attached to starter relay.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: torqueflite NSS? [Re: Darter6] #873024
12/06/10 06:04 PM
12/06/10 06:04 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
According to the print he posted up one wire does.
Re: torqueflite NSS? [Re: JohnRR] #873025
12/06/10 06:08 PM
12/06/10 06:08 PM
San MARcoS, Tx
slant666 Offline OP
slant666  Offline OP
San MARcoS, Tx
i figured out the brown/yellow wire, but what about the double plug w/ blk and blk/wht, there's no where close to stick it.
Re: torqueflite NSS? [Re: slant666] #873026
12/06/10 07:27 PM
12/06/10 07:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That is the wiring for the back up lights and shouldn't stop the car from starting.
Re: torqueflite NSS? [Re: stumpy] #873027
12/06/10 07:53 PM
12/06/10 07:53 PM
San MARcoS, Tx
slant666 Offline OP
slant666  Offline OP
San MARcoS, Tx
isn't one a ground wire? generally that's important to completing the circuit.
i've got an uncle who's a mechanic but more important, his shop has a huge library of service, parts, and repair manuals. he'll help me, i was just looking to avoid the constant reminders that i am not a mechanic and prone to doing mechanical things poorly.
don't swing harder, get a bigger hammer.
Re: torqueflite NSS? [Re: slant666] #873028
12/06/10 08:28 PM
12/06/10 08:28 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
your diagram shows a single wire (vio-blk terminal "p" of the bh connector) going to the rear lights connector and a single white running to the connector to the underdash turn indicator switch.
I'm not sure of your nss, does it have 3, or 4 wires. The body of the switch itself may be providing the ground. I can't recall if you are using a new nss, how many wires in it's connector. I believe it's 3?
Re: torqueflite NSS? [Re: srt] #873029
12/06/10 08:31 PM
12/06/10 08:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The NSS grounds through the trans case. The center terminal of the NSS is the start ground for the starter relay. The two outer terminals on the NSS are the in and out for the back up lights and it doesn't make any difference which is which.
