Intake question? #872769
12/06/10 01:52 PM
12/06/10 01:52 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
K i got a 360 out of a 95 dodge pickup i'm goin to rebuild it this month to drop it in my car and i have no idea where i could find a new intake to convert it back to carburator.So my question is where to find one and what is the correct name for it? i know this is a simple problem but i'm in high school and have no experince to work with so anything is helpful
Re: Intake question? [Re: 1976Fury] #872770
12/06/10 02:01 PM
12/06/10 02:01 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
I beleiev those are the 360"Magnum" and as I recall Edelbrock has carb-type manifolds for them. You could check some part websites (CL, E-bay etc.) but as you said, since you're new at this stuff, there's things to look out for when buying a used alum. manifold, so you may want to save your pennies & get a new one outright.
Re: Intake question? [Re: 1976Fury] #872771
12/06/10 02:05 PM
12/06/10 02:05 PM
an8sec70cuda Offline
http://chucker54.stores.yahoo.net/rpmaima551rp.html
Edelbrock 7577 is an Air Gap 4 barrel manifold to convert the magnum EFI engines to carburetor.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Intake question? [Re: 1976Fury] #872772
12/06/10 02:05 PM
12/06/10 02:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Intake question? [Re: an8sec70cuda] #872773
12/06/10 05:22 PM
12/06/10 05:22 PM
Wyoming, USA
1976Fury Offline OP
1976Fury  Offline OP
Wyoming, USA
Thanks for the help its much needed
