Offset shackles
#872607
12/06/10 12:37 AM
12/06/10 12:37 AM
Posts: 553 Kentucky
clovis
Kentucky
I have a '75 Duster that I was wanting to get a little more tire under. I have a 68 B body 8 3/4 with an 8" wheel and 5.5 offset with a 28 x 10.5 ET drag. I am wanting to see if I could get 28 x 10.5W in there, but I only have about an inch from the tire to the springs. If I were to go with a an offset shackle and front mount do I have to move the spring pads on the rearend? I just want to get to the back of the factory wheelwell. I was hoping I could do it without having to perform any welding.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
