Offset shackles #872607
12/06/10 12:37 AM
12/06/10 12:37 AM
Kentucky
clovis Offline OP
clovis  Offline OP
Kentucky
I have a '75 Duster that I was wanting to get a little more tire under. I have a 68 B body 8 3/4 with an 8" wheel and 5.5 offset with a 28 x 10.5 ET drag. I am wanting to see if I could get 28 x 10.5W in there, but I only have about an inch from the tire to the springs. If I were to go with a an offset shackle and front mount do I have to move the spring pads on the rearend? I just want to get to the back of the factory wheelwell. I was hoping I could do it without having to perform any welding.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Offset shackles [Re: clovis] #872608
12/06/10 12:46 AM
12/06/10 12:46 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just installed a set of offset shackles and front spring brackets on a 68 Hemi Cuda and gained 3/4"+. You will have to relocate the spring pads on the rearend housing
Re: Offset shackles [Re: B G Racing] #872609
12/06/10 03:04 AM
12/06/10 03:04 AM
Brisbane Australia
572B1 Online content
572B1  Online Content
Brisbane Australia
dr diff has a real nice offset shackle kit
Re: Offset shackles [Re: clovis] #872610
12/06/10 10:28 AM
12/06/10 10:28 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Sorry , they have to be welded, no way around that.
Re: Offset shackles [Re: clovis] #872611
12/06/10 12:10 PM
12/06/10 12:10 PM
fullmetaljacket Offline
Make sure if you go with the off set, to remove your electronic ignition box ie: MSD-Accel, etc from the car entirely before welding the perches.
Dr. Diff is your man for the right parts and information the first time.
Re: Offset shackles [Re: clovis] #872612
12/06/10 02:34 PM
12/06/10 02:34 PM
North Branch, MI, USA
notchbackcuda Offline
Dr Diff's parts work great...and he has a painless method for laying out the spring mounts on the rear end housing.
Re: Offset shackles [Re: notchbackcuda] #872613
12/06/10 05:58 PM
12/06/10 05:58 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
Yes they have to be welded and it's a good time to set the pinion angle.
