Tunnel ram carb size? #871511
12/04/10 09:56 PM
12/04/10 09:56 PM
Central NC
gch Online content OP
gch  Online Content OP
Central NC
I am bored and thinking of throwing my weiand Tunnel ram on my 496.I have a general idea for carbs but want some experience from those who have run them.
Bear in mind this is a heavy(4600lb) c body with a mild 496(500hp-575tq est)that runs on pump gas.
Does have ported iron heads that flow well.Solid cam(237*-242* @ .050),9.3-1 compression,1 7/8 headers and 2.5 exhaust.
3000 converter and 3.73 gears.
What do you recommend and why?
Only people who have/had them or who tune for someone who does please.
Re: Tunnel ram carb size? [Re: gch] #871512
12/04/10 10:13 PM
12/04/10 10:13 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Well I run two 9379 Holleys that are 750cfm double pumpers. My combo is 451 4 speed with a pretty heathy cam. For your combo I think two 3310 Holleys (750cfm) would work great.
Re: Tunnel ram carb size? [Re: gch] #871513
12/04/10 10:36 PM
12/04/10 10:36 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
2 Holleys 4779 750 CFM double pumpers. Square jetting all around. No power valve. your combination should be ok with 70 all around. Dual carburetor set up likes less jetting than a single carburetor.
Re: Tunnel ram carb size? [Re: cbarracuda] #871514
12/05/10 10:10 PM
12/05/10 10:10 PM
Kentucky
clovis Offline
clovis  Offline
Kentucky
My combo is close yours and I have tried two different sets of carbs on my Weiand-1850(600) and 4224 (660 center squirters). The center squirters are faster and leave harder. I had to lean the idle circuit out on the 4224 but after that it was all good. I noticed all the hard core racers can spot them a mile away. I actually have both sets of carbs for sale if you are interested.
'75 Plymouth Duster
Phase I 451 906/590/2-660 10.75/126
Phase II 451 Stage VI/590/1050 9.82/135
Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
Re: Tunnel ram carb size? [Re: clovis] #871515
12/06/10 02:21 PM
12/06/10 02:21 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I also have run 2 4779 with no power valves sg jetted @ 78 with choke horns milled off. I also run them some sg jetted @ 80. Don't let anyone fool you they have unreal low-end throttle respond. And they don't look bad either.
I almost forgot the tunnel rams for some reason like a lot of CFM. I have been running tunnel-rams since the 80's. My new engine has a tunnel-ram with 2 Terminators(2950 cfm).
The mistake most people make on the Mopar wedge engine is they like a lot more CFM & fuel than the xxx brand engines.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Tunnel ram carb size? [Re: clovis] #871516
12/06/10 02:38 PM
12/06/10 02:38 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
another vote for 660's
I have them on my 572 Inch hemi, the engine has manners like a 318 2 barrel, until you mash the pedal.
Re: Tunnel ram carb size? [Re: gch] #871517
12/06/10 08:41 PM
12/06/10 08:41 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
i ran dual 600 vac sec, 750 vac sec, 4224 cen squirters, and 750 D.P.
went faster with the D.P.'s
went to a 1050 dominator and ran the same
WAXER
Re: Tunnel ram carb size? [Re: gch] #871518
12/06/10 08:57 PM
12/06/10 08:57 PM
Guitar Jones Offline
My combo isn't any where near yours, it's a W5 363 with a 277/283 duration with .672 net lift flat tappet, 2 inch headers and no exhaust. I run 2 Demon 750 TR carbs with 79 jets all around and .037 squirters.
Not sure how that relates to your combo but everyone said the 750's were too big for mine, Pfft, things leaves hard and runs great, has great throttle response, I can even foot brake the car leaving at 2200 RPM's.
Re: Tunnel ram carb size? [Re: Guitar Jones] #871519
12/06/10 10:11 PM
12/06/10 10:11 PM
Central NC
Central NC
I was thinking( )that two 600's would be fine for the street.Heck it os 496c.i. so two 750's is'nt exactly overkill.
I have one tricked 750 vac sec that I have had for 15 years and on a dozen different cars/engines so maybe I will pick up a core and rebuild it to match.
Already have the intake and linkage so not much left to do.Now if I can air up the flat tire and get motivated
Re: Tunnel ram carb size? [Re: Guitar Jones] #871520
12/06/10 10:20 PM
12/06/10 10:20 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i have a w2 398 that i ran a 1000cfm holley and went to two 1000cfm holleys and it ran better.i down fjetted from 93 to 88 square with two carbs but ran 9.75 to 9.65 with this setup..just my 2 cents............
