Ground my alternator wire. Can someone help? #871484
12/04/10 09:32 PM
12/04/10 09:32 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
I grounded my alternator wire from my cluster and now my battery will not charge. When I take my ground off the battery it dies. Does this mean I fried my alternator? I've read it might have messed up my regulator, can someone help???? Does any one have any ideas?
Re: Ground my alternator wire. Can someone help? [Re: firtdog] #871485
12/04/10 09:59 PM
12/04/10 09:59 PM
scratchnfotraction Offline
what yr is it?
yes it could have zapped the alt and the voltage regulator
i like to change them in pairs myself anyways
could have zaped the print board on your cluster also
need to know yr as they changed in 82-85 and again in 86-88 89-93 IIRC
Re: Ground my alternator wire. Can someone help? [Re: scratchnfotraction] #871486
12/04/10 10:21 PM
12/04/10 10:21 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
You probably fried a fusible link. Use a multimeter and check for continuity between the positive battery terminal and the alternator charge wire.
Re: Ground my alternator wire. Can someone help? [Re: scratchnfotraction] #871487
12/04/10 10:37 PM
12/04/10 10:37 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
Its a 1973 Duster. Slant six.
Re: Ground my alternator wire. Can someone help? [Re: firtdog] #871488
12/04/10 10:38 PM
12/04/10 10:38 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
It did burn the link, but I replaced it.
Re: Ground my alternator wire. Can someone help? [Re: firtdog] #871489
12/04/10 10:39 PM
12/04/10 10:39 PM
oooppss.i was thinking trucks again with the yrs I mention they changed
back to 73 A-body wireing
Re: Ground my alternator wire. Can someone help? [Re: firtdog] #871490
12/04/10 11:31 PM
12/04/10 11:31 PM
which wire did you ground? taking off a batt cable to check if the alt is charging is very hard on the alt, better is to touch a screwdriver to the back center of the alt & see if it is magnetized & if so it is charging (at least some) or pull one of the field leads & see if the ang speed changes. To check the alt put it a fast idle/take off both field leads and ground one (either) male field terminal and jump 12V to the other male field terminal (do this for several seconds max) & if the alt charges then the alt itself is good
Re: Ground my alternator wire. Can someone help? [Re: RapidRobert] #871491
12/04/10 11:44 PM
12/04/10 11:44 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
I ground the hot wire on the back of the cluster that attaches to the ALT tack.
Re: Ground my alternator wire. Can someone help? [Re: firtdog] #871492
12/05/10 12:18 AM
12/05/10 12:18 AM
I ground the hot wire that attaches to the ALT tack.
which wire/terminal are you saying and why did you ground it
Re: Ground my alternator wire. Can someone help? [Re: RapidRobert] #871493
12/05/10 01:28 PM
12/05/10 01:28 PM
Dallas, Oregon USA
firtdog Offline OP
firtdog  Offline OP
Dallas, Oregon USA
I was taking off my cluster and the wire that is hot on the back of my alternator tack grounded on my console and fried the wire before I could un ground it.
Re: Ground my alternator wire. Can someone help? [Re: firtdog] #871494
12/05/10 01:46 PM
12/05/10 01:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Alternator tack? Are you talking about the amp gauge? "tach" is short for tachometer that measures RPM. The ampmeter, oil presuure, temperature and fuel are all gauges. That may help sort out the confusion. Charge the battery and take the car to the local large parts store and have them check the alternator and regulator for you. Most all of them do it for free.
Re: Ground my alternator wire. Can someone help? [Re: stumpy] #871495
12/05/10 04:25 PM
12/05/10 04:25 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
I think we are on the wrong track, here. He surely must have done this ENGINE OFF. He probably did not hurt the alternator or regulator. He MIGHT have killed something in the dash cluster if it was envolved in the short.
What you need to do is trace back THE WIRE THAT YOU SHORTED, you may have to untape some wiring harness---and follow it back.
See if it melted inside the harness and shorted to other wires, both in the underdash, AND the engine bay--I cannot emphasize this pont enough
Carefully check the bulkhead connector that you did not burn the wires off or otherwise burn/ melt/ heat damage the bulkhead connector.
If you replaced the fuse link, the wire that you shorted should now be hot again--as it obviously leads to the battery. It should be "hot again."
If not, there's still an open IN THAT ONE WIRE
