Ground my alternator wire. Can someone help?
#871484
12/04/10 09:32 PM
12/04/10 09:32 PM
Posts: 38 Dallas, Oregon USA
firtdog
Dallas, Oregon USA
I grounded my alternator wire from my cluster and now my battery will not charge. When I take my ground off the battery it dies. Does this mean I fried my alternator? I've read it might have messed up my regulator, can someone help???? Does any one have any ideas?
Re: Ground my alternator wire. Can someone help?
[Re: firtdog]
#871485
12/04/10 09:59 PM
12/04/10 09:59 PM
Posts: 15,487 Florida
scratchnfotraction
what yr is it? yes it could have zapped the alt and the voltage regulator i like to change them in pairs myself anyways could have zaped the print board on your cluster also need to know yr as they changed in 82-85 and again in 86-88 89-93 IIRC
[Re: scratchnfotraction]
#871486
12/04/10 10:21 PM
12/04/10 10:21 PM
Posts: 4,417 Michigan
MarkZ
Worthy
Worthy
You probably fried a fusible link. Use a multimeter and check for continuity between the positive battery terminal and the alternator charge wire.
