Re: Any chance a 22" radiator will cool a 470 ? [Re: DennisH ] #871416
12/04/10 10:27 PM
12/04/10 10:27 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Hey Mark,my issues with running hot are all over this site..Couldn't get it to cool no matter what I did ..the larger radiator fixed it just fine..I still have that Afco,,It has a little oops on it now ..A (friend ) tried it and his flex fan flexed too much at high rpm..it can be fixed ok ..soo. Any way I cant wait to see that Sears car run...Thought I was going to have to go to KY too see it..I had to build a 493 stroker for myself as the 512 and 505 strokers I built for some guys cars are killing me..Keep on wrenchin,and welding and painting..Larry
Re: Any chance a 22" radiator will cool a 470 ? [Re: Hemi Allstate] #871417
12/04/10 10:44 PM
12/04/10 10:44 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
This car wears it's original 22" radiator.
Engine is a 511"- 13:1 ported Edelbrock heads, etc.. Easy 650 horse.
180 all day.
MB
Mike,
I won't doubt your word, but things are looking hot in the picture!
That is more engine than what I am using for sure.I may have to give the old original a try. Is yours a 2 row?
Thanks,
Mark
As most are aware there are several issues that can cause overheating conditions in cars that range from too strong a mix of glycol/water to a bad impeller on the pump, to a bad fan clutch and so on. People are very quick to blame the radiator because that is conventional thinking. And in some cases, the larger capacity radiator just masked a problem that existed elsewhere.
The problem with running a 26" radiator in the 22" support is that unless you cut the support out, you will be blocking the 4" of extra core anyway. Even then, there is no way to properly mount the radiator without some jury rigging.
All things working well, the 22" will be fine. Have the core replaced with a high efficiency unit.
MB
Re: Any chance a 22" radiator will cool a 470 ? [Re: HPMike] #871418
12/04/10 11:35 PM
12/04/10 11:35 PM
Mansfield,Ohio
moparrulzzz Offline
moparrulzzz  Offline
Mansfield,Ohio
Weren't there some cars that came off the line with a smaller core opening with the larger radiator? A 26 in. opening with a 28" radiator comes to mind. ( I could be wrong)
Wouldn't the lost 4 or so inches make little difference since the capacity is there?
Re: Any chance a 22" radiator will cool a 470 ? [Re: HPMike] #871419
12/04/10 11:37 PM
12/04/10 11:37 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Hi Mike,Even with the 24 inch rad I had to (adjust) the radiator support..It's a 56 Plymouth..It took a ton of modifing just to get that 440 in that car..even more after I installed the f body K frame..I went thru the whole list of things that make it run hot..Shrouds,,different w/pumps,Used the stock oem w/p housing,even different pullys,engine tune etc,,heads and head gaskets.even changed blocks..you name it..30 + years as a Chrysler tech,both auto and marine..This car just wanted more radiator..My problem was hot at speed..I could sit in traffic and run 180..but hit 3000 rpm and boil..It took a while but the 26 inch rad fits nicely..dual fans from a Chrysler LHS are only needed when stopped..
Re: Any chance a 22" radiator will cool a 470 ? [Re: dynamite] #871420
12/04/10 11:47 PM
12/04/10 11:47 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
A 22" radiator will do it if it is the same quality as an OEM unit and you don't have low gearing.
The '70 440-6 Sport Fury GTs with 3.23 gears came with a 22" radiator. If they could cool a heavy 440 C body, they should cool a lighter 470 B body.
I have a '70 440-6 Bee with the original 22" and 3.23 gears, never had an overheat problem here in FL.
Re: Any chance a 22" radiator will cool a 470 ? [Re: B5 Bee] #871421
12/04/10 11:50 PM
12/04/10 11:50 PM
Mansfield,Ohio
moparrulzzz Offline
moparrulzzz  Offline
Mansfield,Ohio
So a 22" in my '68 Coronet with a 440 and 3:91's probally won't work!??
Re: Any chance a 22" radiator will cool a 470 ? [Re: Hemi Allstate] #871422
12/04/10 11:55 PM
12/04/10 11:55 PM
Orange County, CA
Mike H Offline
Mike H  Offline
Orange County, CA
I have heard a product called Water Wetter makes a significant difference. Supposedly it reduces the surface tension of the water, allowing it to make better contact with the nooks and crannies inside the casting, more efficiently conducting away heat. Makes sense. I run it in my 355 hp 383, 22" 3-core. Never gets above 160.
Re: Any chance a 22" radiator will cool a 470 ? [Re: moparrulzzz] #871423
12/05/10 12:15 AM
12/05/10 12:15 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It probably will IF everything is equal or better than OEM.
Would Mopar engineer a cooling system that was on the edge? Likely not. There should be a margin of safety in the design to handle 3.91 gears if you cruised at 65mph or less, 75mph maybe not.
One thing that we now have that helps cool our old cars they didn't have 40 years ago. E10. If you have your car jetted up for E10, the extra fuel will help cooling at all speeds. Best way to fix a overheating problem without replacing cooling system components, convert the fuel system over to E85.
Re: Any chance a 22" radiator will cool a 470 ? [Re: B5 Bee] #871424
12/05/10 12:16 AM
12/05/10 12:16 AM
Mt. Eden Ky.
Hemi Allstate Offline OP
Mt. Eden Ky.
B5Bee,
I have never heard of the '70 440-6 Sport Fury GTs! That sounds interesting.
My RR is 3.23 equipped. I have to admit that I didn't consider the rear gear ratio as part of the equation. But,it seems Ma did, as the cars with the optional rears had bigger radiators? Is that correct?
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Any chance a 22" radiator will cool a 470 ? [Re: HPMike] #871425
12/05/10 03:03 PM
12/05/10 03:03 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
180 all day.
MB
Mike,
Thanks,
Mark
MB
As usual, Mike knows what he's talking about. All rads are not created equal and the 26" cure all mentality is prevalent with Mopar guys.
Installing a 26" rad in a 22" car has the issues Mike mentioned above plus if you want it to look original....
Use the 22" tanks with a good high performance core and make sure all the other cooling system components are up to snuff.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Any chance a 22" radiator will cool a 470 ? [Re: DPelletier] #871426
12/05/10 03:47 PM
12/05/10 03:47 PM
Mt. Eden Ky.
Mt. Eden Ky.
Dave,
Are the replacement cores 3 row or two? I think the original core in my RR is two row.I know that the spacing of the tubes is different as is the fin count, and tube size.
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Any chance a 22" radiator will cool a 470 ? [Re: Hemi Allstate] #871427
12/05/10 04:01 PM
12/05/10 04:01 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Put A supercuda/Poopercuda spring in the lower radiator hose and it'll cool just fine hahahah
Re: Any chance a 22" radiator will cool a 470 ? [Re: Hemi Allstate] #871428
12/05/10 08:36 PM
12/05/10 08:36 PM
Canada north shore lake Ontari...
ross Offline
ross  Offline
I have a 68RR with a 451 3800 converter and 3.91 gears. I have driven it for thousands of miles from Ontario to Alabama and raced in 95 degree weather. I have the stock 22 inch rad that came in my car. I have a shroud and use the Mopar thermal fan. Yes it gets warm occasionally in stop and go traffic . I have an external electric fan that blows on my tranny cooler for times like this. It works fine for me and I occasioally tow a small trailer.
Ross
Re: Any chance a 22" radiator will cool a 470 ? [Re: ross] #871429
12/05/10 11:08 PM
12/05/10 11:08 PM
Mt. Eden Ky.
Mt. Eden Ky.
Ross
Ross,
I think that
you are putting more heat to the system (3800 converter) than I plan too, and the 22" is working. That is encouraging. I hadn't thought about a cooler for the trans! It must be my age! LOL
Thanks,
Mark
1996 Ram 1500 Sport
1968 road runner
Re: Any chance a 22" radiator will cool a 470 ? [Re: DPelletier] #871430
12/05/10 11:37 PM
12/05/10 11:37 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
180 all day.
MB
Mike,
Thanks,
Mark
MB
Mentality: There is no replacement for displacement. Even coolant. More is better.
Overbuild.
Re: Any chance a 22" radiator will cool a 470 ? [Re: DennisH ] #871431
12/07/10 07:30 PM
12/07/10 07:30 PM
DPelletier Offline
DPelletier  Offline
Overbuild.
Correct: you can have more coolant in a 3 row 22 inch core compared to a stock 2 row 26.
Re: Any chance a 22" radiator will cool a 470 ? [Re: DPelletier] #871432
12/07/10 09:00 PM
12/07/10 09:00 PM
GA
Boosted Offline
Boosted  Offline
GA
I have ran the champion 3 core aluminum in my cars with no issues.. I have the 26" in place of my 22" in the Challenger with a 512 in it.. No issues and it was a simple as drilling 4 holes and using some 5/16 fuel hose as spacers... Fits like it came thant way. I did not cut the radiator support as it only blocked an inch or so on the sides...
I would never go back to a stock radiator in anything that I was building a non stock motor for. If it was going to be a resto yes.. but not a hot rod... I can get picks if you like...
Here is a general view of it in the car... Want anymore and I can get them.
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Any chance a 22" radiator will cool a 470 ? [Re: Hemi Allstate] #871433
12/08/10 03:11 PM
12/08/10 03:11 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I have the original 22" rad. in my 68 road runner. It cools the .030 over 383" with out any issues, and there is no fan shroud. I am using the MP clutch fan assy. ( Although it is dangerously close)
The new engine is a mild 470" with Eddy heads and hydraulic cam.
Anyone using this setup with the a similar low deck stroker?
Thanks,
Mark
I have had good luck with a 22" rad in front of a 472 CI 658HP Hemi. Hottest it ever got was 185. Depends on a lot of factors (make sure all the air deflectors/hood seals are in place, proper T-stat, good water pump etc.) Make sure the timing is set correctly and you are not running too lean.
I found clutch fans a little tenuous at idle. I went to a solid 16" flex-a-lite fan. Temperature only goes up a few degrees at idle and drops right down once moving. Fan shroud is a must.
Re: Any chance a 22" radiator will cool a 470 ? [Re: torkrules] #871434
12/08/10 04:39 PM
12/08/10 04:39 PM
PA
Jack Zupan Offline
Jack Zupan  Offline
PA
I had good luck running my 383 with a stock 22" radiator in my roadrunner. It used the small fan, no clutch and no shroud. In fact, the engine probably ran too cool. I replaced the radiator when I put in a 600 hp hemi because I wasn't sure it would be enough. I got a 22" triple flow copper/brass radiator from US Radiator. I used the same fan and no clutch. I can't remember what thermostat I used. The engine runs very cool no matter the amient temperature nor whether it's at idle. I would really recommend them but it was expensive. The reason I made that choice is I didn't want to chop up the car to fit a 26" radiator or drill extra holes. I didn't want to go with most aluminum radiators because they are butt ugly in my opinion and I wanted a more or less stock look. Finally I would recommend Water Wetter, I have used it in all my cars and think it does help keep the system cool and efficient.
