Help me solve an arguement... #870852
12/04/10 03:56 AM
12/04/10 03:56 AM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
My buddy and I are arguing about a very simple subject I think... I could be wrong.
I'm trying to convince him that on a steel block, aluminum headed engine, as it warms up the lash loosens up. He tells me it gets tighter.
Please tell me I'm right
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Help me solve an arguement... [Re: DemonDust] #870853
12/04/10 03:56 AM
12/04/10 03:56 AM
MD
Kevins493 Offline
Kevins493  Offline
MD
you are correct. Easiest argument to make is the aluminum heads expand at a much higher rate (vs temp) than the steel or moly pushrods. I believe cast iron does as well. just not looking it up now. so basically you are making the pushrod seem "shorter" in relation to the distance between the lifter and the rocker (or technically adjuster) so you have more clearance.
Re: Help me solve an arguement... [Re: DemonDust] #870854
12/04/10 04:00 AM
12/04/10 04:00 AM
Suburb of Chicago, IL
BCFKody Offline
BCFKody  Offline
You're right. In my experience the lash loosens up .004 - .005 of an inch.
Re: Help me solve an arguement... [Re: BCFKody] #870855
12/04/10 04:04 AM
12/04/10 04:04 AM
Menomonee Falls
Menomonee Falls
Thanks guys I haven't adjusted lash since last winter and my memory was foggy... Getting ready to race soon and it brought the conversation up....
SDG Motorsports
Re: Help me solve an arguement... [Re: DemonDust] #870856
12/04/10 04:04 AM
12/04/10 04:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My experiance with aluminum headed iron block engines is the valve lash opens up as the engine gets hotter. I normally set the cold lash at 0.006"/0.008" on the old 451 with B-1 b/S heads.
Re: Help me solve an arguement... [Re: DemonDust] #870857
12/04/10 04:10 AM
12/04/10 04:10 AM
Your correct, aluminum expands eight times more than steel and cast iron when heated to the same temperatures as each other Google aluminum expansion rates, one of my old Crane Cam catalogs says to set the lash .002 loose when setting the valves on a cold cast iron motor, set them .006 tighter cold with aluminum heads on a cast iron block and set them .012 tighter cold on a aluminum block with aluminum heads. I found that information to be accurate on the first all aluminum street Hemi motor I built and on many other mtors since with iron blocks and aluminum heads you do want to check each motor to make sure those settings is what that motor needs and wants
Re: Help me solve an arguement... [Re: Cab_Burge] #870858
12/04/10 11:04 AM
12/04/10 11:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yeah I use .006 as the cold/hot difference.. then I
also run my lash .010 tighter than spec calls for
but still with the .006 difference
Re: Help me solve an arguement... [Re: MR_P_BODY] #870859
12/04/10 11:17 AM
12/04/10 11:17 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Even though it's a pain at times, I always make a point of checking the lash hot. That's what the engine actually sees, so it makes the most sense. Eliminates the guesswork.
Minor lash variations can make some significant horsepower swings(both ways) on some engines, so it's always a good idea to have this ironed out.
MB
Re: Help me solve an arguement... [Re: HPMike] #870860
12/04/10 11:21 AM
12/04/10 11:21 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
NEVER HEARD OF ANY METAL SHRINKING IN HEAT
Re: Help me solve an arguement... [Re: HPMike] #870861
12/04/10 12:43 PM
12/04/10 12:43 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
MB
X2...... The way I explain it is that since the aluminum expands so much, it's actually pulling the rocker arms away from the block......
If you can't handle the truth, you're living a lie.......
Re: Help me solve an arguement... [Re: Big Squeeze] #870862
12/04/10 12:49 PM
12/04/10 12:49 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Check lash hot on one cyl. Recheck cold, calibrate the other 7 holes to that one. Not my tip, I got it here from another member.
Re: Help me solve an arguement... [Re: MR_P_BODY] #870863
12/04/10 01:51 PM
12/04/10 01:51 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I guess you dont like roller cam valve chatter
Re: Help me solve an arguement... [Re: emarine01] #870864
12/04/10 01:58 PM
12/04/10 01:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
No its not that... I need all the lift I can get,
one of these days when I get a few bucks I'll have
it reground for another .100 lift(I went wimpy the
first time around)
